MK5 2.5 EGR blanking
Postby carr16v » Sun May 04, 2014 8:01 pm
I finally decided to remove my egr valve on my 94 2.5 turbo diesel with epic injection. So I took some photos and have attached them for anyone that might be interested. First photo is the removal of the egr valve and inlet housing.
Image[/URL]
Second photo is blanking plate fitted.
Image[/URL]
Next photo is the surface on the housing that I had to resurface as it wasn't flat.
Image[/URL]
This was because egr flange surface had corroded away.
Image[/URL]
Blanking plate for inlet housing.
Image[/URL]
Two blanking plates welded together.
Image[/URL]
Then I had to grind some clearance between blanking plate and inlet pipe flange.
Image[/URL]
Blanking plate fitted. I put fitting holes in plate so I could bolt egr valve in plate. This meant ecu still could see the egr valve so no errors or limp home mode.
Image[/URL]
Finally a lick of paint. Probably should of used high temp paint but this will do for now.
Image[/URL]
Straight forward enough. A good road test now but seems a bit more response. I would of been losing some boost from the corroded egr flange.
carr16v
Re: MK5 2.5 EGR blanking
Postby rich666 » Fri Apr 15, 2016 7:45 am
good idea man!
rich666
Postby derv23 » Fri Apr 15, 2016 12:42 pm
Nice one. Iv'e blanked all my Di's in the past but not got round to the turbo yet. Was a bit worried about throwing up an error code/light. :)
MK5 Tourneo.
derv23
Postby ceurieusneus » Fri Apr 15, 2016 5:46 pm
Can anyone tell me for what reason Ford original placed this EGR valve?
Can anyone tell me allso why I would be better off with blanking this valve? :oops:
2.5 Di non turbo 71HP
Writing was not invented to look for spelling errors :wink:
Ford Anglia '62, Mercedes 200 '86, Transit ambulance/camper '88, Mercedes CE300 '89, caravan Puck '75
My ambulance conversion
ceurieusneus
Postby ceurieusneus » Fri Apr 15, 2016 5:52 pm
Forgot in the previous post...
Nice work!
ceurieusneus
Postby dyte2004 » Fri Apr 15, 2016 6:16 pm
ceurieusneus wrote:Can anyone tell me for what reason Ford original placed this EGR valve?
Egr is exhaust gas recirculation, they are fitted to reduce emissions and are bad because they put smelly exhaust poop back in the inlet ,in theory they should reuse any unburnt fuel in the exhaust but in practice they block up inlet manifolds ,well that's my take on them
dyte2004
Postby Jim Archer » Sat Apr 16, 2016 8:24 am
EGR passes a 'regulated' amount of exhaust back into the inlet to slow down the combustion cycle, this is to reduce combustion temperature and thus reduce the amount of Oxides of Nitrogen (NOx) produced at low revs.
DIs were particually bad for this as they actually have a bit of grunt low down.
In reality what the EGR does is fill the inlet manifold/tract with shite and slow turbo spool time on TDs.
DIs, both NA and TD can be blanked off without any issue, easiest way is a couple of blanking plates the same shape as the gaskets either end.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby Realist » Sun Apr 28, 2019 3:18 pm
Sorry to drag up this old post up but can I just blank off the manifold, seal the pipe, remove the EGR totally and leave it at that?
Running the Bosch conversation.
Realist
Postby Noctule » Sun Apr 28, 2019 4:04 pm
Yes, just blank it. On turbo engines the egr is controlled by the ECU, which becomes virtually redundant when a manual Bosch pump is fitted.
Mat
2012 Mk7 125t350 camper conversion in progress
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 190 HiCube DRW self-built camper
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby Realist » Sun Apr 28, 2019 4:11 pm
Thank you.
Noctule wrote:Yes, just blank it. On turbo engines the egr is controlled by the ECU, which becomes virtually redundant when a manual Bosch pump is fitted.
Mat
Realist
Postby transitzmk5 » Mon Sep 18, 2023 1:47 am
blanked my mk5 TD 2.5 off and worked for 800km then light came back on. Now trying to source a new EGR completely…
transitzmk5
Postby Coakers » Sat Jun 14, 2025 8:12 am
Sorry to resurrect a 9 year old statement but did you sort your EML issue? I'm just about to blank mine off.
Coakers
Users browsing this forum: Almu
