Cool.
Thanks Jim. Thought that might be the case.
As I said, I CAN HAZ WELDUR. I CAN HAZ WELD. So fabricating various pipes and flanges isn't a problem.
As in F111ORY's post, up there ^^, that seems like a neat idea, although with slight modifications.
I note the author of the "job" says he used a LR200 turbo. They seem to be a bit thin on the ground.
If flanges are made to fit, and its a mechanical actuator (ie not electrical bits) can any turbo (that'll fit a 2.5) be used, or are there certain ones I should look out for?
I realise I'm being a bit of a PITA, but you guys seem to know, and the internet is fairly useless for transit info.
Ta
