Hi, I have been getting the occasional problem with my pats module refusing to unlock for around 5-10 attempts with reinserting key i.e the led flashes fast preventing starting (flashing code it gives means no communication with pats module). Usually happens when am away from home but ity has often done this on the first attempt but been fine on the second. i have 3 keys and have tried all three but still the same. When it plays up it will take quite a few goes for the led to stop the rapid flashing and go off . I dont know if its the reader around the key barrel but have unplugged it and plugged it back in, also the pats module plug. The code makes me think its between the key reader and the module but I really dont know for sure. A new reader would be the best place to start unless someone here knows different? Also , would a replacement reader need coding to vehicle or not?
many thanks
