by finn_mccool » Sat Apr 30, 2016 6:04 pm
Looks like it'll need a lot of welding!
Reason(s) for failure
Nearside Rear reflector excessively damaged so that its function is impaired (1.5.1c)
Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Nearside Front Body has a sharp edge caused by corrosion (6.1.C.1)
Offside Front Body has a sharp edge caused by corrosion (6.1.C.1)
Offside Front Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Advisory notice item(s)
Nearside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Offside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Offside Front suspension has slight play in a lower suspension ball joint (2.5.B.1a)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Vehicle structure has slight corrosion (6.1.A.1)
