Front spring hanger repair
Postby MinorMatt » Sun Jun 12, 2016 3:56 pm
Has anyone here actually fitted a new front spring hanger to a mk5?
We all know that the panels available are mk3 - but i have just found out they won't fit my van correctly.
The mk5 chassis is straight and goes up to, and welds to, the front crossmember, wheres the mk3 doesn't. The spring hangers that are available all have a"kink" where the chassis stops on a mk3 and this does not work with a mk5 chassis!
Needless to say the van is now in bits and I will have to put something back!! Not sure quite what I am going to do yet!
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: Front spring hanger repair
Postby ernie b » Sun Jun 12, 2016 6:49 pm
Do you mean this one (click on the pics for full size, not 100% on resizing them)
I fitted one from central panels last year
Absolute B and a half to get the remains of the old one off
I just trimmed back the top so it would fit up into position on the chassis rail properly
You will also find the mounting holes for the bolt are also too big
On the mk5 there is a piece on either side like a large washer, I salvaged these from the old one and transferred them to the new panel
Everything lines up where it should (I'm a touch ocd about that)
Left the welds showing and was straight up with the tester and had no problems getting a fresh ticket
ernie b
Postby MinorMatt » Sun Jun 12, 2016 8:03 pm
Yes one of them...
The mk5 hanger doesn't have the returns on the top flange or the ones at the side either.
I'm probably going to unpick the repair panel and remake it to be correct for mk5
93 L GL Minibus
Postby J.R.Solutions_82 » Sun Jul 17, 2016 8:29 am
J.R.Solutions_82
Postby J.R.Solutions_82 » Sun Jul 17, 2016 8:44 am
J.R.Solutions_82
Postby MinorMatt » Sun Jul 17, 2016 1:13 pm
Funnily enough thats more or less what I did in the end!!
93 L GL Minibus
Postby Cutecub.x » Wed Nov 01, 2017 7:50 pm
Hi,
Im new to this so please forgive my 'bonde' mistakes
Lol
Ernie b, u put a pic up of sum leaf spring hanger brackets
They are the ones ive been looking for!
My old horse box is desperately in need of a new pair & i was wondering where i cud buy them from?
Ive found ones on ebay that say they will fit
But they arent the same
& the pic u put up is the exact ones
Ne chance u can point me in the right direction please on where i can buy them from?
Or if ne1 can tell me where i can buy them i wud been extreamly greatful
Thank u
Cutecub.x
Postby DodgeRover » Fri Nov 03, 2017 9:32 pm
He says he fitted one from central panels - if that's the one in the picture or not I don't know.
DodgeRover
Postby ernie b » Sun Nov 05, 2017 10:41 pm
The one I fitted was from central panels but I've just checked their site and the item picture has been updated.
The new item pic looks much more correct for the later independent front you can see the lack of a return lip on the upper edge and the addition of the wshers where the bolt goes through
These were always a problem part as I'm sure you can pick up from the discussion when fitting with independent front end.
I'd contact central panels directly and clarify.
Or I'm sure it could be modified to fit with a little work
ernie b
Postby Cutecub.x » Wed Apr 04, 2018 9:53 am
Hi all,
I finally found/brought the leaf spring brackets for my horsebox/ford transit,
But the problem i now have is finsing sum1 to change them!
Im in lyne, surrey (nr woking)
Ive had lots of quotes but keep being let down wen it comes to actually doing the work
Does ne1 know of ne1 that can change the brackets over
Cut old ones off & weld new ones on
I dont have the confidence to attempt it myself
(Havent welded in 10yrs & never done nething structural)
I desperately need them doing
Can ne1 help me find ne1 that can do the work?
Please
Thank you
Cutecub.x
Postby cherniy_chack » Wed Apr 04, 2018 7:17 pm
Hi, Cutecub.x.
Replacing the central panel is not a problem for me, but I live very far away from you.
Ласкаво просимо до Київа.
Аffectionately asked to Kiev. (ukr)
Welkome to Kyiv
This is my friend's car.
We could not find the central panel and had to sculpt from pieces.
cherniy_chack
Postby cherniy_chack » Wed Apr 04, 2018 7:30 pm
That's what happened as a result.
In my country there is no MOT.
The welded seams were cleaned by the owner of the machine, she applied and cleaned the putty and painted over the repair area.
cherniy_chack
Postby Cutecub.x » Thu Apr 05, 2018 11:25 am
Hi,
One of ur photos looks pretty much like wots happened to my horsebox
Such a shame ur not closer
Im having so many problems trying to find sum1 to do it
& they are all really confusing me!
Im dreading the thort of having to try it myself
Cutecub.x
Users browsing this forum: Altransit, estellef
