What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby derv23 » Wed Sep 13, 2017 8:06 pm
Mk5swbhighroof wrote:Replaced knackered old plastic lensed headlights for new glass lensed ones.
Secured starter battery.
Found rain water running into drivers footwell from somewhere above the steering column bulkhead fitting... :shock: :cry:
Could be the windscreen or wiper scuttle fixing screws.
Or somewhere else..
MK5 Tourneo.
derv23
Postby Mk5swbhighroof » Fri Sep 15, 2017 3:29 pm
Or somewhere else..
Removed scuttle, cleaned underneath, and refitted. Awaiting rain (not really... :shock: ) to see if that worked.
Took apart and cleaned the brakes. New rubber seals for pistons to be ordered.
Removed remaining portion of cabin rubber floor mat.....
Mk5swbhighroof
Postby Mk5swbhighroof » Sat Sep 16, 2017 8:20 pm
Replaced rear brake shoes, and handbrake cable. In pouring xking rain.
Found another hole in the chassis, by the rear spring hanger... not impressed.
Mk5swbhighroof
Postby goldcoast » Tue Sep 19, 2017 9:30 am
Replaced a heater hose that had rubbed a pinhole in it against the cylinder head
Fitted a Blanking plate to the EGR pipe at the exhaust manifold end.
Replaced the alternator belt - 4PK1490
Now trying to replace the Power steering and air-conditioning belt 6PK1420 - but just can not get it over the pulley - even with the tensioner fully up !
2000 Mk 5 RWD 2.5 TDI LWB Manual 5 High Roof White
1997 Mk 5 RWD 2.5 TDI LWB Automatic Mid Roof White
+ previously 2008 Mk7 LWB T350 6 speed High Roof
:lol:
goldcoast
Postby Mk5swbhighroof » Thu Sep 21, 2017 6:05 pm
Fitted and adjusted new handbrake cable properly. Removed old handbrake cable.
Loosened the n/s front hub nut a touch, as the bearing was getting a touch warmer than the other.
Fingers crossed for mot tomorrow.
Mk5swbhighroof
Postby Mk5swbhighroof » Fri Sep 22, 2017 2:21 pm
Passed the MOT.... :D
(Including another hole, but only as an advisory...)
Mk5swbhighroof
Postby vanfox » Fri Sep 22, 2017 3:26 pm
Failed MOT, bad plates and headlights too high! First ever time had headlights too high.
Took 200kgs weight off back end, front end comes down, all back to normal. New number plates and another 12 months of.....heaven?
vanfox
Postby BROWNYS V6 » Sat Sep 23, 2017 6:52 pm
i had a coolant leak for too long, so decided to see if I could find it today, oops, engines all over the garage floor now :roll:
BROWNYS V6
Postby BROWNYS V6 » Wed Sep 27, 2017 10:33 pm
started bolting it back together tonite.
BROWNYS V6
Postby HairyFool » Sat Sep 30, 2017 12:48 pm
Polished the plastic headlamps back to as new clarity :D
Worked out the wiring as to where the Base wiring ends and the motorhome starts. Had to chuckle cos the bloke selling was so proud that his electric step worked despite being parked up for 6 months, had a solar panel fitted to keep the hab battery charged.
The step is driven by the van batteries.
HairyFool
Postby angusp » Sun Oct 01, 2017 7:49 pm
Front nearside wheel off & washer bottle removed and undersealed the arch. Only 3 more & the rest of the underneath to go!
2000 mk5 100 swb, going.
2005 mk6 350 lwb, not going.
2005 mk6 280 lwb, gone bang.
1996 mk5 190 lwb, gone.
1998 mk5 80 swb, gone.
angusp
Postby barryorbik » Sat Oct 07, 2017 6:40 pm
Just back from a completely trouble free 1,500 mile trip around Germany, Holland and Belgium in our 1997 Transit MK 5 2.5TD based Autosleeper Legend. Got back late on Friday (yesterday) and the MOT was at 9.00 a.m. this morning and she passed with flying colours plus the overall fuel consumption with mixed (M25 slog) motoring and some sustained sections at +120km/hour came out at 27 mpg.
As a reward I am now treating her to a gearbox and back axle oil change with some Slik 50 added to the gearbox to help quieten the slight whine in 4th and 5th, plus I have just ordered new front and rear shockers as she still has her factory original 20 year old ones on a present and although they are not leaking I figured they may have lost a little of their damping efficiency by now.
The cab bodywork, especially the doors is getting a bit 'rust bumpy' in all the usual places but I cannot find any doors in this area that are any better, so I plan to cut out the rust and re-metal them over the winter. Interestingly we spotted quite a few MK 5 transit based motorhomes during our trip and they all seemed to have excellent doors with no signs of having been patched up, so was it only the UK ones that were fitted with duff ones?
Looking forward to many more trouble free trips overseas with her and Spain is beckoning but I think a trip to Poland may be a better option, as rumour has it that they have loads of spares for MK 5's over there.
barryorbik
Postby angusp » Sun Oct 08, 2017 8:40 pm
Changed the front brake pads.
angusp
Postby BROWNYS V6 » Sat Oct 14, 2017 11:39 pm
my helicoil kit arrived, so fixed the buggerd thread on my inlet manifold :)
BROWNYS V6
Postby angusp » Tue Oct 17, 2017 9:22 pm
Drove it out from my local garage after the pats system packed up and immobilised the van. They've replaced with new, hopefully the AA should pick up the bill under the breakdown repair insurance and off I go again.
angusp
