What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby finn_mccool » Sat Jul 14, 2018 10:25 pm
gotgcoalman wrote:
finn_mccool wrote:Took her for her MOT...
She failed. Massively!! :cry:
How massively?
Lots and lots of welding...
finn_mccool
Postby gotgcoalman » Sat Jul 14, 2018 11:13 pm
How massively?
so normal stuff then?
can you DIY?
Too bloody quiet :shock:
gotgcoalman
Postby cherniy_chack » Wed Jul 18, 2018 5:06 pm
A couple of weeks ago I bought a wooden pallet on the floor of the car.
At installation I saw a strong corrosion of the floor at the junction of the cabin and the cargo part.
For me, eliminating such damage is not a problem, but I'm old and I have no desire to do anything at all. :lol:
If it's good weather, I'll do it next weekend.
cherniy_chack
Postby dick » Fri Jul 20, 2018 5:04 pm
i'm sorry to say that i scrapped it, too much agro to get through a test etc etc
dick
Postby gotgcoalman » Fri Jul 20, 2018 6:15 pm
dick wrote:i'm sorry to say that i scrapped it, too much agro to get through a test etc etc
must have been really bad :(
gotgcoalman
Postby Noctule » Sat Jul 21, 2018 12:25 pm
Gave it a pat and a 'there, there, you'll get us there' after the exhaust downpipe split next to the flexi.
only an 80s music fest and a 300 mile drive home to go.
At least now I know the turbo is winding up fine. Mind you, so does most of Perth this morning. :D
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby gotgcoalman » Wed Jul 25, 2018 6:42 pm
Got the drivers mirror twatted on a back road by a prat in a Merc van on his phone.
Couldn't get turned around to give chase (shithead didn't stop)
Wouldn't have caught up in my Di anyway :(
have a spare arm with cracked surround and good mirror.
Is it possible to pop the good mirror off the ball joint without breaking it?
gotgcoalman
Postby cherniy_chack » Thu Jul 26, 2018 6:14 pm
gotgcoalman wrote:Is it possible to pop the good mirror off the ball joint without breaking it?
Maybe.
I dismantled the mirror in details.
But it's easier to remove the fixing rim and replace the mirror insert.
It was raining on weekends, I did not repair the car.
I went to the forest for mushrooms, but did not find mushrooms, but brought firewood.
Yesterday the alternator broke, I drove about 200 kilometers on the battery.
This morning I went to the car market and bought a new alternator Mitsubishi 95 A
for 110 dollars, has already installed. Also bought a new voltage regulator unit, but has not yet repaired the old alternator.
cherniy_chack
Postby Noctule » Mon Jul 30, 2018 11:14 pm
Fitted shiny new downpipe!
Had to take a chance on one off eB*y as Andrew Page's couldn't come up with the right one. My cat is fitted just in front on the silencers, but Page's drawing shows the cat in the downpipe! Pipe turned out to be the correct one, although it's listed as 2.0 TD non-cat! I suspect the 2.0 is a mistake, and non-cat is the alternative to having a cat in the downpipe. Pipe code is BM70335 from BM Catalysts. It's a really good fit too, I didn't even have to modify/remove the support bracket on the back of the gearbox.
- DRW with 16" rims
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby gotgcoalman » Tue Jul 31, 2018 12:05 am
I got a full exhaust the other year and had to point out what I needed in the exhaust booklet at the factors :lol:
It's a mish mash of 96/97/99 bits :?
fits all the hangers :D
bloody ford must have used left over bits :roll:
gotgcoalman
Postby Noctule » Tue Jul 31, 2018 12:17 am
I can't fault them on the quality of the parts though. The whole system was still the original, the parts were made in '99, and then modified from full length to side exit when it was converted to minibus to allow for the tail lift.
- DRW with 16" rims
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby Noctule » Tue Jul 31, 2018 7:42 am
- DRW with 16" rims
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby gotgcoalman » Tue Jul 31, 2018 6:03 pm
Sorted the mirror. With the help of Mr prybar.
It's do able although I thought it had broken a couple of times
Sent from my Plus E using Tapatalk
gotgcoalman
Postby cherniy_chack » Tue Jul 31, 2018 6:29 pm
Today I replaced the faulty voltage regulator on the Mitsubishi alternator and assembled it. To replace the voltage regulator, I needed a soldering iron for 100 watts, rosin, solder and a hook, to separate the regulator pins from the rectifier pins.
The work took about 1 hour.
The machine is equipped with a new generator.
Retracted inside the brush regulator by fixing the wire through the holes in the body and brushes .
cherniy_chack
Postby angusp » Fri Aug 03, 2018 10:32 pm
New exhaust front pipe & gasket fitted.
2000 mk5 100 swb, going.
2005 mk6 350 lwb, not going.
2005 mk6 280 lwb, gone bang.
1996 mk5 190 lwb, gone.
1998 mk5 80 swb, gone.
angusp
