What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby BROWNYS V6 » Fri Mar 31, 2017 5:43 pm
had a run out in the van last nite to a passion ford meet, need to sort the rearend out as I'm sure its getting lower :roll:
BROWNYS V6
Postby angusp » Fri Mar 31, 2017 6:09 pm
Oil change & new oil/air/fuel filter and 2 new tyres on front.
2000 mk5 100 swb, going.
2005 mk6 350 lwb, not going.
2005 mk6 280 lwb, gone bang.
1996 mk5 190 lwb, gone.
1998 mk5 80 swb, gone.
angusp
Postby steve t » Sun Apr 02, 2017 3:48 pm
took all the seats out of my minibus and fitted a rock n roll bed :D
steve t
Postby transitjack » Thu Apr 06, 2017 10:22 pm
nothing,i welded my flareside up must be 6 months ago but still havent given it to the man with the stick to prod its bits,to be honest ive no use for it but after what must be 12 years ownership i cant seem to want to let her go
formerly babystepside
transitjack
Postby CamperVanBeethoven » Sat Apr 08, 2017 3:32 pm
Just been spending the day taking out all the campervan bits from inside, so the coachbuilder can lift the ply and have a look at the floor underneath. Saved me a few hundred quid in labour. But means I'll have to put it all back in again :/
He was welding bits at the front while I was taking stuff out the back.
Some interesting things were found during disassembly, such as the fact that the output wires on the 240V MCB were loose ... :o
Shocking ...
Also, the repair panel he got doesn't match the side of my van. The side sill of the van has had a patch repair done over the original body, and the body juts out further than it should!
CamperVanBeethoven
Postby gotgcoalman » Sat Apr 08, 2017 5:17 pm
used bread to get the pilot bearing out :D
Too bloody quiet :shock:
gotgcoalman
Postby CamperVanBeethoven » Sat Apr 08, 2017 11:32 pm
gotgcoalman wrote:used bread to get the pilot bearing out :D
Bread?! Umm, how?
CamperVanBeethoven
Postby gotgcoalman » Sun Apr 09, 2017 8:50 am
Bread?! Umm, how?
1 slice of either brown or white bread will do(I tried with both)
tear pieces off the slice and push then into the centre of the bearing to fill the void behind it.
Use a hammer and something that is a reasonable fit in the centre of the bearing
to act as a drift.In my case a 4lb hammer and a 1/2" drive T bar.
stuff the hole and then use the hammer and "drift" to compress the bread.
keep stuffing the hole and compressing the bread until enough pressure is created to pop the bearing out.
don't forget to gouge the bread out before fitting the new bearing :wink:
Nasty bearing out and new 1 fitted in under 10 minutes :D
I've been told it works with thick grease as well (the drift would need to be a good fit though)
gotgcoalman
Postby CamperVanBeethoven » Sun Apr 09, 2017 9:29 am
I see! I suppose you could use Plasticine or anything else that's compressible ... but some breadcrumbs are unlikely to cause problems in the engine and the filter would probably catch them - but Plasticine could screw up bearings.
CamperVanBeethoven
Postby MinorMatt » Sun Apr 09, 2017 10:40 am
2nd vote for bread! I get it wet though ;)
The bread will not go in the oil/bearings
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Altransit » Sun Apr 09, 2017 10:47 am
MinorMatt wrote:2nd vote for bread! I get it wet though ;)
Well well, I have never heard of that, until today :!: 8) :)
Postby gotgcoalman » Sun Apr 09, 2017 12:39 pm
Flywheel back on 23nm and 25 degrees. Just a little over finger tight :lol:
for those doing the timing belt.............
here's the correct hole to pin (from the back)
which way does this go again?
oh well 50/50 chance of getting it right.
there's something written on it but i didn't have my glasses :lol:
centered the plate using the "finger" method. i'm confident it's spot on.
Might dig my "tool" out just to check,if I can find it (7 years since it was last used)
oooooooooooooohh shiny :D
meanwhile the gear box is "marinading" in pound shop oven cleaner to get all the oily gunge out of it :roll:
forgot to mention the gearbox mount was worse for wear.
stuck it for now with toolstation "stixall" (poor mans tigerseal)
Just checking haynes for clutch torque settings.
ahhhhhhhhh 30nm :idea:
gotgcoalman
Postby angusp » Sun Apr 09, 2017 8:43 pm
Removed front bumper to clean metalwork behind, pleased to find no rust issues.
angusp
Postby gotgcoalman » Tue Apr 11, 2017 7:08 pm
Used the van today and..............
clutch nice and light as compared to the old one.
no leaks evident in the bellhousing/under the van :D
on the down side :(
resealed the diff inspection plate.(it's been weeping for ages)
took the plate off and
stuck my gloved hand in to scoop as much of the old smelly oil out and came
across this.(not the £2 coin)
chunk off the pinion :lol:
bearing had a bit (a lot) of play so I adjusted it and took it out for a test run.
No vibration or clunking.
could it have been like this for the 2 years i've had the van?
next question......
Are the pinion and crown wheel machined as a pair?
or
can i just buy a pinion to match the diff ratio?
and............
how to set pre load at home :wink:
on a plus it's not neds Tdci :lol:
gotgcoalman
Postby CamperVanBeethoven » Tue Apr 11, 2017 8:57 pm
Didn't do anything but I went to see it. I need a new rear floor :(
Bugger.
CamperVanBeethoven
