What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby davetheshrew » Thu Jun 07, 2018 1:39 pm
fitted a intercooler off a mitsy shogun warrior today, my god this van is flying now, near a bar of boost, feels like its going to take off!
Drab green Transit 190 L High top minibus
turbo conversion with toyosports intercooler
davetheshrew
Postby gotgcoalman » Thu Jun 07, 2018 5:57 pm
Bugger all cos it's broken :( :lol:
Too bloody quiet :shock:
gotgcoalman
Postby Fastfish » Thu Jun 07, 2018 9:23 pm
Well today I welded in a new NSF rear arch, found small hole behind it so plated it.
Wire brushed underneath the NS Sill and painted in navy blue gloss
Finished filling and smoothing the welded in patch on the OSR
MOT time soon ,then a new clutch as since I swopped out the EDIS and turned up boost a bit its slipping, but to be fair it does light up the rear tyres in second which is nice
Fastfish
Postby gotgcoalman » Fri Jun 08, 2018 7:07 pm
Started tackling this.
Out with the old and in with the new.
1 job half done ImageImageImageImageImageImage
Sent from my Plus E using Tapatalk
gotgcoalman
Postby gotgcoalman » Sat Jun 09, 2018 3:11 pm
Took the shoes off today and cleaned/lubed the "self adjusters".
washed the back plate off with thinners and decontaminated the braking material,then put it back together.
Sat watching bubbles going through the pipe during the initial bleeding and noticed a brown spot on the chassis.
SO
I gave it a poke with the screwdriver.
Guess what.
I found a hole :lol:
gotgcoalman
Postby Fastfish » Sat Jun 09, 2018 9:55 pm
Gotgcoalman them shoes would last a mighty long time mind lolz
Fastfish
Postby gotgcoalman » Sat Jun 09, 2018 11:38 pm
Fastfish wrote:Gotgcoalman them shoes would last a mighty long time mind lolz
innit :roll:
gotgcoalman
Postby BROWNYS V6 » Sun Jun 10, 2018 9:57 pm
gave the ol banger an oil change today, and turned it round in the garage to fix another hole I found :roll:
BROWNYS V6
Postby gotgcoalman » Mon Jun 11, 2018 4:29 pm
refitted the repaired alternator (£61.80) new brushes/regulator.
bled the brakes fully now the servo is working.
cleaned and welded the hole that had disguised itself as a brown patch on the chassis.
gotgcoalman
Postby finn_mccool » Mon Jun 11, 2018 7:27 pm
Final prep for new windscreen later this week.
finn_mccool
Postby cherniy_chack » Tue Jun 12, 2018 5:16 pm
gotgcoalman,you gave an excellent idea of fixing the pistons of the brake cylinder plastic tie!
I almost finished assembling the motor without a head.
I will give this engine to a friend who gave me two fuel pumps.
He already drove a car to Kiev from Odessa.
cherniy_chack
Postby finn_mccool » Wed Jun 13, 2018 9:57 pm
(Finally) put a new windscreen in!!
finn_mccool
Postby Chug » Wed Jun 13, 2018 10:18 pm
finn_mccool wrote:(Finally) put a new windscreen in!!
Did you fit it yourself finn?
Chug
Postby finn_mccool » Thu Jun 14, 2018 4:20 pm
No. Wanted it done right!! :D
finn_mccool
Postby vmaxman66 » Thu Jun 14, 2018 6:32 pm
With the sun shinning, I went out and changed the cambelt (Gates) power steering fluid, oil an filter change plus air and fuel filters. Tomorrow will be new rear shoes and cylinders. All good once again.
vmaxman66
