transit-town wrote:Changed timing belt,water pump,power steering belt,thermostat housing & thermostat, alternator belt,flushed coolant housing,pipes and radiator
transit-town wrote:transit-town wrote:Changed timing belt,water pump,power steering belt,thermostat housing & thermostat, alternator belt,flushed coolant housing,pipes and radiator
Bobiow wrote:Just been having a look at the heater controls (now winter is over ) to see if I can make it switch between floor/dash/windscreen a bit easier = Failed and gave up on that, it works enough... In the process found a spare ignition key and somehow made the interior light work.
CamperVanBeethoven wrote:May post up some pics tomorrow
