What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby finn_mccool » Mon Feb 05, 2018 11:29 pm
BROWNYS V6 wrote:sod all today :)
Ain't that the truth? Too bloody wet!
finn_mccool
Postby Mk5swbhighroof » Tue Feb 06, 2018 8:31 pm
cherniy_chack wrote:
I think many transit owners make it easier to adjust the timing of the injection.
I love a good home bodge.... Please tell us all about that tap :shock:
Mk5swbhighroof
Postby Mk5swbhighroof » Fri Feb 09, 2018 2:18 pm
Fixed the heater hose with gaffer tape and cable ties. Now to find some replacement coolant hoses... :(
Mk5swbhighroof
Postby gotgcoalman » Fri Feb 09, 2018 5:51 pm
Got 2 tyres :D
£117
Same as were on the front and lasted about 30k :D
Too bloody quiet :shock:
gotgcoalman
Postby angusp » Fri Feb 09, 2018 6:40 pm
New water pump, cambelt & tensioner, alternator belt, power steering belt fitted and coolant replaced.
Let the garage take the strain (abery motor centre, hitchin) - 3 hours labour charge. Very pleased.
2000 mk5 100 swb, going.
2005 mk6 350 lwb, not going.
2005 mk6 280 lwb, gone bang.
1996 mk5 190 lwb, gone.
1998 mk5 80 swb, gone.
angusp
Postby gotgcoalman » Fri Feb 09, 2018 9:06 pm
angusp wrote:New water pump, cambelt & tensioner, alternator belt, power steering belt fitted and coolant replaced.
You defeatist.
Get out in the cold/rain/sleet/snow and DIY
:lol:
gotgcoalman
Postby cherniy_chack » Sat Feb 10, 2018 12:42 pm
I wanted to show that cutting off the upper part of the cam belt protection, you can easily adjust the timing of fuel injection. :lol:
On the fuel return line from the injection pump I installed a small fuel heater.
In winter, the coolant is taken from the connection in the thermostat housing and through a three-way valve is fed into the heater and further into the expansion tank of the cooling system.
In summer, the tap directs the coolant directly to the expansion tank.
When the winter frost is more -10 gr C, it helps.
cherniy_chack
Postby finn_mccool » Sun Feb 11, 2018 8:52 pm
Welded on another new bit of windscreen channel, just before it started snowing (again).
finn_mccool
Postby BROWNYS V6 » Sun Feb 11, 2018 10:16 pm
sod all today, again, I was laying bricks in the snow :roll:
BROWNYS V6
Postby Mk5swbhighroof » Mon Feb 12, 2018 1:43 am
Changed oil and filter, and whilst down there, slapped some underseal around.
Mk5swbhighroof
Postby Noctule » Mon Feb 12, 2018 11:36 am
Filled up the fresh water tank. Yes, that's dull, but we are in Pompeii at the moment.
It's the first time i've parked up under orange trees!
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby gotgcoalman » Tue Feb 13, 2018 10:33 pm
Un clogged the underseal gun ,some arsehole put it put it away last year full of underseal :roll:
Blacked the "few bits" I've welded so all the cow sh*t and road salt doesn't make matters worse.
MOT due soon :lol:
gotgcoalman
Postby ned » Tue Feb 13, 2018 10:46 pm
gotgcoalman wrote:Un clogged the underseal gun ,some arsehole put it put it away last year full of underseal :roll:
MOT due soon :lol:
So it not just my van covered in cowshit n road salt then :lol: I was following a bloody horse this morning that decided to sh*t right in front of my van :roll: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby gotgcoalman » Tue Feb 13, 2018 11:24 pm
MOT due soon :lol:
Did you pick it up?
good for roses or so i'm told.
gotgcoalman
Postby ned » Tue Feb 13, 2018 11:49 pm
MOT due soon :lol:
Did you pick it up?
There wasn't much left to pick up after the ditch finders rolled though it :? Its probably splattered over the underside of Lucifer now :lol: rust protection? Good, pile horse sh*t to the cil on the left :lol: N
ned
cron
