What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby gotgcoalman » Sun Jan 21, 2018 4:02 am
ned wrote:
gotgcoalman wrote:Just hit the 200,000 mile mark in mine
Sent from my Plus E using Tapatalk
Your catching me up :wink: fancy a race :?: N
only if we're both fully loaded ned.
I'll load mine upto 3500kg with coal.
you can use what you want.(2 boxes of tissues and a turnip should see yours fully laden)
standing 1/4 an i'll give you a 5 minute headstart.(how long does it take to read the fault codes on a mk6?)
:wink: :wink: :wink: :wink: :wink:
Too bloody quiet :shock:
gotgcoalman
Postby ned » Sun Jan 21, 2018 9:53 am
Ah that depends on whether the code reader can be arsed working or not, its a bit like the youth of today :lol: :lol: :lol: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby bambi mk 1 » Sun Jan 21, 2018 11:08 am
When the flag drops the bullshit stops Ned :lol:
bambi mk 1
Postby Noctule » Thu Jan 25, 2018 1:36 pm
Painting a sill repair. The camper is fitted with a slide out step, but as usual the sill had rotted through from the inside, probably because the water drains had been filled with sealer to stop water dripping on the step, but that was 17 years ago so can't complain. The bracket for the step was a length of 6mm x 60mm bar welded to the inner sill with 6x inch-long welds. It's now an extended 3mm plate (which is still thicker than the bracket on the step itself) welded to the body panel which becomes the middle bit between the inner and outer sill, which would have needed replacing anyway even if the step was taken away.
Mat
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby Kjeles » Thu Jan 25, 2018 10:26 pm
Mounted an engine block heater in the frost plug hole.
No more cold starts.
Kjeles
Postby cherniy_chack » Fri Jan 26, 2018 7:44 pm
So shoot the fuel jets into the combustion chamber in the bottom of the piston.
For many years I have been using such a hybrid booster pump.
But recently his "leg" broke. He replaced it with another one.
In this photo, the booster pump is installed on the unit after a complete overhaul of the engine.
cherniy_chack
Postby angusp » Fri Jan 26, 2018 10:37 pm
Latest addition.
2000 mk5 100 swb, going.
2005 mk6 350 lwb, not going.
2005 mk6 280 lwb, gone bang.
1996 mk5 190 lwb, gone.
1998 mk5 80 swb, gone.
angusp
Postby cherniy_chack » Sun Jan 28, 2018 8:50 pm
I exchanged serviceable Lada VAZ 2106 for the faulty Ford Transit mk3 1990 with the details of the engine lying in the cabin. It was 11 years ago.
Since that time I have repaired the body, changed the rear axle, changed the details of the front suspension, switched to 15 "and 16" wheels, crashed the engine and I again made a complete engine repair.
The last thing I did was install the turbocharger and replace the conventional Bosch injection pump with 0 460 414 153 at the Bosch injection pump with turbocharger 0 460 414 154.
cherniy_chack
Postby finn_mccool » Sun Jan 28, 2018 10:03 pm
Welded a little more on to the windscreen surround...
finn_mccool
Postby Noctule » Wed Jan 31, 2018 9:47 pm
Sealed a leaky top hatch. 500mm flat hatch on slightly curved roof profile plus 18 years in the sun (or indeed our Great British gloom) equals eventual sealant shrinkage. Tiger Seal saves the day.
Replaced the jammed-shut ashtray with a second 12v accessory socket and double USB. To make sure things don't get left on charge (eg sat nav) I've wired them into the split charge circuit for the fridge.
Mat
- DRW with 16" rims
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby Kjeles » Fri Feb 02, 2018 10:59 am
Adapted a pair of good, old, spiked snow chains to the rear wheels and a pair of new, flimsy, easy-fit chains for the front wheels.
Now I'm ready for some steep, snowy mountain slopes.
Kjeles
Postby cherniy_chack » Fri Feb 02, 2018 4:24 pm
I think many transit owners make it easier to adjust the timing of the injection.
cherniy_chack
Postby gotgcoalman » Sat Feb 03, 2018 1:21 pm
Got up this morning full of good intentions.
Service van and do a bit of welding.
Priced the stuff up on euro the other week.Oil/filters came to £56 with the up to 50% off promo :shock:
didn't bother and went to local motor factor instead.
Same order came to £43 :lol:
and........
it's not stopped raining all morning :(
there's always tomorrow I suppose.
gotgcoalman
Postby gotgcoalman » Mon Feb 05, 2018 7:20 pm
used it to go to work :D
got home and.........
changed the oil and had a poke about (mot due)
Got the welder out :lol:
did the worst (I need a smaller tapping hammer)
Most of the bits were previous owner welding smeared with car bodge and covered to look good :roll:
ordered more mig wire :shock:
gotgcoalman
Postby BROWNYS V6 » Mon Feb 05, 2018 11:05 pm
sod all today :)
BROWNYS V6
