What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby bambi mk 1 » Mon Mar 05, 2018 9:15 pm
gotgcoalman wrote:
Noctule wrote:New front discs and pads. The old ones were a tad on the worn side...
The newness appears to worn off them a bit :wink:
Nothing a rub of a Brillo pad wouldn't cure :lol:
bambi mk 1
Postby Noctule » Tue Mar 06, 2018 11:01 am
When the crunchy noise informed us that brakes were not quite how they were when i'd set out I pulled up and used a file to knock the crumbly edges off the disc which helped to get me home.
Mind you, 'set out' was Sankt Goar on the Rhine and 'pulled up' was Sinzig on the Moselle, and 'get home' was via Belgium and the Netherlands. It serves me right for taking that detour through the Black Forest the day before.
Don't blame me for bringing the weather back with us though, it wasn't yet snowing in Rome when we left.
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby cherniy_chack » Wed Mar 07, 2018 8:31 pm
In my MK3, the driver's seat cushion collapsed.
I had a seat of an unknown Ford.
Of the two seats I gathered one, but not yet welded it to the frame.
cherniy_chack
Postby BROWNYS V6 » Sat Mar 10, 2018 11:21 pm
been rubbing filler on the other wing and arch today.
BROWNYS V6
Postby cherniy_chack » Sun Mar 11, 2018 3:22 pm
Two weeks did not use the car, it was a lot of snow.
Today left, went to buy potatoes.
I drove about 50 km, the engine warmed up, the radiator warmed up, and the cooling liquid remained in the system.
It seems that the head gasket is OK.
cherniy_chack
Postby cherniy_chack » Tue Mar 13, 2018 5:41 pm
Today I managed to achieve the tightness of the non-return valve of my self-made compressometer from the FT injector!
The systematic error of the pressure gauge is 2 bar.
Tomorrow I will try on the machine.
cherniy_chack
Postby gotgcoalman » Wed Mar 14, 2018 2:07 pm
Today I have nackered my diff :(
Too bloody quiet :shock:
gotgcoalman
Postby vanfox » Wed Mar 14, 2018 5:00 pm
R U interested in a 4.1-1 crown wheel and pinion? New with a used diff to rebuild it into.
vanfox
Postby gotgcoalman » Wed Mar 14, 2018 7:01 pm
vanfox wrote:R U interested in a 4.1-1 crown wheel and pinion? New with a used diff to rebuild it into.
cheers for the off but managed to find a complete axle locally.
£145 delivered.
Dunno what ratio it is although it's come out of a recovery truck the scrapyard used until the body work fell to bits :(
gotgcoalman
Postby cherniy_chack » Fri Mar 16, 2018 5:26 pm
Today I measured the compression of my motor in the third cylinder.
Pressure 38 bar.
This is an excellent result!
In the other cylinders, measurements were not made-the motor has recently been overhauled.
Poor quality video, sorry.
https://www.youtube.com/watch?v=DQCsKiWsPqM
Photos turned out better.
cherniy_chack
Postby BROWNYS V6 » Fri Mar 16, 2018 11:34 pm
sod all today.
BROWNYS V6
Postby BROWNYS V6 » Sun Mar 18, 2018 8:35 pm
been rubbin primer down
BROWNYS V6
Postby axam102 » Sun Mar 18, 2018 10:56 pm
Took the dogs out and got stuck in the snow. found that a transit is pretty good at digging down, throwing lots of crap about and moving again. I just love the van its mental
axam102
Postby gotgcoalman » Mon Mar 19, 2018 6:48 pm
dropped the buggered axle and started replacing with a dubious looking "allegidly alright"
second hand one.
Ratio unknown :(
gotgcoalman
Postby gotgcoalman » Mon Mar 19, 2018 9:03 pm
Lol spot the buggered one.
And WTF on the U bolts.ImageImage
Sent from my Plus E using Tapatalk
gotgcoalman
