What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby vanfox » Thu May 17, 2018 6:48 pm
Rust, glorious rust!...yus, took the W reg van for MOT. Failed on corrosion in all the awkward places, inner wings, shocker turrets, spring mountings, rear crossmenber, etc, etc, etc.
That's a lot of welding lying down so..... Has anyone tried using a spit type contrivance to make it easier to get at the underside without lying down. There's few on Ebay, just wondering if they'll take the weight, 1800kgs or whether you need to remove the engine? Anyone???
vanfox
Postby cherniy_chack » Sun May 20, 2018 6:47 pm
Work from a pit or overpass.
I increased by one turn the screw of the cyclic feed on my TNVD Bosch VE of type 154 with a turbocharger.
Noticeably increased power at low speed, there is no smoke in all modes.
cherniy_chack
Postby cherniy_chack » Tue May 22, 2018 5:22 am
Yesterday I filled up a full tank and counted the fuel consumption.
92 liters per 1220 km.
7.54 liters / 100 km or 37.46 miles per gallon (GB), or 32.1 miles per gallon (US) (?)
In the UK and the US, different miles or different gallons?
I looked at the calculators of magnitudes, the English gallon is much larger than the American one, by about 15 ... 20%.
Miles are about the same.
cherniy_chack
Postby cherniy_chack » Wed May 23, 2018 7:54 pm
I began to collect another engine based on a bore of +65 mm cylinder block and polished -0.25 mm crankshaft.
I'm planning a turbo engine, but with atmospheric pistons.
He installed a camshaft, crankshaft and one piston.
I have a problem: there is no oil dipstick tube.
I think to make a probe tube from a copper 1/2 "pipe.
I have such a pipe.
cherniy_chack
Postby BROWNYS V6 » Wed May 23, 2018 9:33 pm
been flatting out a couple of runs in my new paint, hope i don't forget the polisher from work tomorrow.
BROWNYS V6
Postby finn_mccool » Sat May 26, 2018 3:10 pm
Welded the last hole in the windscreen pillar. Just some tidying up to do then it's a new windscreen!! Yay!
finn_mccool
Postby paul1956 » Sun May 27, 2018 12:58 am
friday took my mk3 1990 for mot its going to cost me £40 to have the welding done :D :D :D
paul1956
Postby cherniy_chack » Wed May 30, 2018 2:16 pm
Finally I made a tube for the oil dipstick.
Copper tube 1/2 "and a stamped copper transition from diameter to diameter was brazed by copper-phosphorus solder.
cherniy_chack
Postby HairyFool » Wed May 30, 2018 10:02 pm
Two new batteries :( BOGOF at Euro car parts :D
Passenger side held down by a webbing strap but a little tug and the end behind the battery came out with a ball of rust on the end. Life is never simple.
HairyFool
Postby cherniy_chack » Thu May 31, 2018 6:27 pm
Today I installed the copper tube of the oil dipstick and the adapter plate on the front of the motor.
cherniy_chack
Postby BROWNYS V6 » Mon Jun 04, 2018 9:57 pm
been cleaning it :roll:
BROWNYS V6
Postby gotgcoalman » Tue Jun 05, 2018 6:05 pm
walked past mine to get to the car this morning and then again this afternoon :lol:
Too bloody quiet :shock:
gotgcoalman
Postby ned » Tue Jun 05, 2018 6:23 pm
gotgcoalman wrote:walked past mine to get to the car this morning and then again this afternoon :lol:
Has it not recycled itself :shock: :lol: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby gotgcoalman » Tue Jun 05, 2018 6:40 pm
I have a welder and i'm not affraid to use it :lol:
Any way it's a robust Mk5 not one of those Mk6 things :wink:
gotgcoalman
Postby gotgcoalman » Wed Jun 06, 2018 5:45 pm
Alternator couldn't make it's mind up today on the van.
Volt meter in cab showing 14v then down to 12v :(
Dash light never came on :?
Tested when I got home and voltage direct from the alternator was not good :(
Alternator off to get the part number and it's 1 of those where the replaceable stuff is burried inside :(
Then I noticed a pool of fluid under the van.
Looks like rear brake cylinder has joined the party to make my day worse. :lol:
gotgcoalman
cron
