VMH wrote:Have you tried releasing the self adjuster mechanism?
There is a hole in the backing plate that you can push a screw driver through to release the cam.
Just a thought before you smash anything off.
I had the same problem. Spent hours with crow bars and hammers before i realised this.
dumper wrote:Remove the half shaft undo nuts remove washer and bearing then bolt the half back on the wrong way round so you can use it as a lever move shaft op and down or Side to side and pull at the same time this is assuming it’s a fully floating axle and the shaft is held on with six nuts or bolts then you can press the hubs on h g v s and p s v s with knockout wheel studs we some times knock out the studs to make it easier to separate them when the vehicle
