dumptruck wrote:Clutch release arm is where the end of the clutch cable is attached, gearbox end.
Search previous forum posts for ' clutch arm ' and you'll find more info and pictures of that part.
BROWNYS V6 wrote:when you replaced the clutch, did you fit a new spigot bearing in the end of the crankshaft ?
Bakas wrote:BROWNYS V6 wrote:when you replaced the clutch, did you fit a new spigot bearing in the end of the crankshaft ?
Yes sir, the whole kit was replaced. Leaves only the gearbox right? So far we have drove 2000 km on some very bad Ukrainian roads and the problem has slightly intensified but only occurs when operating reverse or first gear in traffic, so are keep going towards Moldavia.
Users browsing this forum: mokjumbo
