Hi, new to the forum.
I bought an 1998 150 LWB Semi-high roof, 2.5TDi, that started it's life as a 9 seater personnel transport for the fire department, it seems to be in brilliant condition all in all, no rust so far, serviced regularly and very few kilometers on the meter. It's registered as a 3 person van now with the extra seats in storage and we will be travelling with it during the summer.
It's running 225/70R15 both summer and winter tires. I'm going to get the steel rims painted black and would like to get the end of the axle covered with a black center cap along with some black wheel bolt/nut covers.
My plan was to order Ford's genuine center cap cover and some aftermarket bolt covers, see links below:
http://www.ebay.ie/itm/Genuine-FORD-Tra ... xyOMdS-Jos
http://www.ebay.com/itm/TPI-Injected-Bl ... SwMgdXz~OC
But my question now after removing the silver hub caps that it came mounted with is, will the Ford Center Caps fit and if so, how do they mount to the center of the wheel? My front and rear axle "ends" also look different from each other. So my other question is, do the axles on my Transit look like the regular stock variants or some kind of custom order (it has an diff lock that is electrically controlled on/off from the dashboard) by the fire department when they bought it new?
In the pics below the one with the rusted centre is the rear axle.
Thanks in advance for you help!
