I have a transit 2.5 di powering a pressure washer now the problem I am having is the small diesel pump on the side of the engine is falling, I assume because it isn't liking the constant heat it is being subject to with the washer being mounted inside a insulated box body and running 10 hours a day right beside the exhaust manifold and the main exhaust then running right beside it again
Now i want to do away with it all together and run a universal electric diesel pump can anybody see a problem with this working
Any particular spec needed to run a di any recommendations of a particular brand good or bad
Any help appreciated
