Tires... will they fit? 215/75 R15 BFGoodrich All terrain
Postby eresseraca » Sun Jan 29, 2017 8:04 am
I'm running Nokian 225/70/R15 studded winter tires...
I'd like to run some beefier AT tires in the summer. BFG All Terrain come in 215/75/R15.
Anybody tried that size, narrower but sidewall 75 instead of 70... will they rub?
eresseraca
Re: Tires... will they fit? 215/75 R15 BFGoodrich All terrai
Postby pigroaster » Sun Jan 29, 2017 9:07 am
eresseraca wrote:I'm running Nokian 225/70/R15 studded winter tires...
Where do you live that you need studded winter tyres? Would like to see what a transit looks like on bfg's
Sent from my SM-N910F using Tapatalk
pigroaster
Postby Aardvark » Sun Jan 29, 2017 11:17 am
I doubt there would be any problem fitting those. I looked up the dimensions of both sizes athttps://tiresize.com/and there is less than a third of an inch height difference and one inch extra circumference that will make your speed about 1% faster at the same revs so your speedo will be up a little.
Learning to love rust.........
Aardvark
Postby MinorMatt » Sun Jan 29, 2017 1:03 pm
So long as the load rating is high enough there shouldn't be an issue
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby vanfox » Sun Jan 29, 2017 1:23 pm
.... and one inch extra circumference that will make your speed about 1% faster at the same revs so your speedo will be up a little.
From experience, more circumference = faster speed for the same speedo reading, may be just enough to trip a camera. Your speedo will read low, i.e. 30 on the dial will actually be about 32 on the road and so on. 60 could be 65.
Best check it with a sat nav.
vanfox
Postby twin wheel camper » Mon Jan 30, 2017 12:21 am
Weight rating won't be high enough the said tyres have a weight rating of 100/97 so won't be heavy enough for a six stud transit assuming with it being fitted with 225/70/15 110 rating (normally) before that's what your fitting them on :!:
twin wheel camper
Postby eresseraca » Mon Jan 30, 2017 2:31 pm
pigroaster, up in Finland, so studded is the way to go with our nordic winters... imo :) Whichever I choose I'll be sure to post some pics for you!
MinorMatt & twin wheel camper you are correct, the one's I was looking at were: LT215/75 R15 100/97S 6PR All-Terrain T/A KO2... DANG! :oops: Thanks for pointing this out to me though.
Seems almost impossible to find a All terrain tire with enough load rating for a 150 LWB... Sucks!
The only one that comes close is the Bridgestone Dueller at 225/75R15C 110/108S. So the new million dollar question is, is it impossible to squeeze 225/75R15 on the Mk5?
eresseraca
Postby eresseraca » Mon Jan 30, 2017 2:49 pm
Searching around a bit, found this thread from back in the day: viewtopic.php?f=4&t=176978
Re: 225/70/15 tyres
Post by MrMPuk » Sat Jul 05, 2008 12:20 am
I had 225/75r15 on my SWB on the alloys.
SOOO, I guess it's possbile... or what do you guys think? :mrgreen: (and I guess I have to recalibrate/change the speedometer gear in that case)
eresseraca
Postby rimotu66 » Mon Jan 30, 2017 3:33 pm
IRC Bridgestone Dueller's are standard fitment on Mitzi L200's, a lot of people soon replace them as they are terrible off road and on wet tarmac.
2007 SWB 110PS GLX Mk7
rimotu66
Postby eresseraca » Mon Jan 30, 2017 5:19 pm
rimotu66, the L200 stock tires are the HT version I think, Bridgestone Dueler H/T 687, load rating 105T.
The one's I'm looking Bridgestone Dueler A/T D697, load rating 110/108S
eresseraca
Postby eresseraca » Mon Jan 30, 2017 9:25 pm
There's no tire though that looks as tough as the BFG All terrain though, so that's def. what I would want.
How do the fire department do it (see pic/link below)... if the load rating is that much too low, the car's the same 150 lwb right... don't get it , they just ignored the load rating? :D :roll: Of course they might not load it full as it's a speciality vehicle with one purpose, but still... or are those 16" wheels with something like 225/75...would give a load rating of 115/112S. Anyone with a good wheel size eye :wink:
http://www.jsharples.co.uk/ford-transit ... ervice/312
eresseraca
Postby twin wheel camper » Mon Jan 30, 2017 10:31 pm
They are most likely a larger size 235/75/15 maybe then the load rating might just get you away with a 150 model
twin wheel camper
Postby gotgcoalman » Mon Jan 30, 2017 11:10 pm
road noise might be an issue :wink:
although our vans are that noisy it might not be a problem :shock: :lol:
Too bloody quiet :shock:
gotgcoalman
Postby brickent » Tue Jan 31, 2017 10:23 am
Take a look at Wrangler Duratracs. They look aggressive yet not too noisy on pavement.
brickent
Postby Mfr » Tue Jan 31, 2017 11:31 am
What about these? http://www.fedimatyres.com/en/tyres/com ... /winter-ms They are commercial and load rated to a Transit 190. I have them on mine just now, good road manners and not too noisy.
viewtopic.php?f=2&t=135873
Mfr
