So related to my recent passenger airbag install thread and also to install aluminium decoration rings around the speedo/rev meters. I need to remove some parts of the dashboard to access, swap and install the new cabling.
First off, yes I will unplug the minus pole from the batteries 30min before I start, don't want to get caught in there with an airbag going off
1. Where's the airbag control module located? I need to unplug and remove the cable that attaches the steering wheel airbag and replace it with the new cable harness that attaches both the steering wheel and the passenger airbag to the control module, so where behind the dash does the control module sit?
2. Steering wheel and airbag removal procedure, is this correct?
- loosen two bolts behind the steering wheel that holds the airbag in place, unplug and remove it.
- then loosen the bolt that holds the wheel in place and pull it till it comes off, if needed. Best case scenario I'll get by, by just threading the new cabling in without needing to remove the wheel completely.
3. How do I remove the trim around the stereo, and the stereo itself (RDS3000)?
- figured if I get these out of the way I can probably manage to get the cabling for the passenger airbag in place through the center console.
4. How to remove the glove box for the last part of the passenger airbag install and connection?
5. How do I get the speedo cluster out for installing the alu rings and replacing the meter bulbs with LEDs (got clear ones ordered for this)?
Found some threads on this but none that really told me how to get it out of the dash, unfortunately.
So any and all help I can get is very appreciated!
