by Geoff Dyson » Sun Feb 12, 2017 9:23 pm
Hi all, I'm trying to help the old guy who lives near to me, he owns a 1988 F Reg transit campervan with no or very little brakes which we narrowed down to a faulty Master cylinder. No problem I say's "will Get an replacement from E Bay a quick bleed up and then its off to for the mot and your back on the road."
Shorten a long tale, A specialist in london replies "go to a breaker yard I don't keep stock that old"!!!. So Armed with the Reg Number and Chassis Number I then spend over a week of texting Emailing on the phone to locate a replacement Cylinder (yes I know its a mine field of possible's that could have been fitted) I locate one that's not a perfect mach on the reservoir fitment but looks 99.9 Percent a match, Sadly the reservoir is out by 2/3mm in length and the bore is to large for the old one to fit
So I need your knowledge and assistance in locating a Master Cylinder for this vehicle. I don't know the make of the Cylinder (IE lockheed bendix or girling), but I can say it has 3 outlets pipes 2 on the side & one just below the front outlet. The plastic reservoir has two inlet caps one with level indicator rearward and it is secured to the main body of the cast metal cylinder via 2 phillips headed screws. I have found several lookalikes online and in pictures but they only have 2 pipe outlets
Can anyone help in the make of this Cyl or a replacement part number's to give to parts suppliers for them to try and match up something to fit. It's that bad have been asking them to look at 2.8 Ford granada/sierra or suchlike that may fit & give him a stronger brake pedal and get this old boy back moblie again but again no luck so Any help in locating a cylinder or knowledge of new or even a pre loved in good working order greatly received
Thanks in advance for your time and Help
Thanks again Geoff
