hey guys
since i have done the 2.5 di to 2,5TDI conversion have a strange issue
the Speedo is 15km out of wack eg speedo says i am dong 100km but in reality tested with GPS says i am doing 85km and when my wife driving at 100km in front i am miles back
So i have the original Mk4 dash cluster in ( you know the one with the Clock in the Center ) cable driven from a upgraded A4LD Auto trans with the VSS connection
So the old A4ld MANUAL KICKDOWN on the 2.5DI using same Instrument Cluster worked fine
I have even tried the upgraded Cluster with the Tacho built in Cluster and have even tried the diffrent speedo cables NO Diffrence to Speed Readings
What is causing this mismatch on the Speedo ?
The 2.5TDI & Gearbox A4lD are all off the same Vehicle including the Speedo Just not the Speedo Cluster but i wouldnt think it would make a diffrence because they are both cable driven
please feel free to ponder this problem
all help Appreciated
Cheers
Wayne
