FORD TRANSIT CAMPER VAN 2.0 PINTO COLD START
Postby lukeh6n2 » Sun Mar 05, 2017 10:38 pm
hi guys
recently bought a 2.0 G reg ford transit camper van but having a few issues starting from cold.
it does start but requires you to hold the revs for a minute or so then it will idle ok
she does backfire if you let revs off and does cut out right away
what should i be looking for?
on a G reg does it run unleaded or leaded fuel?
hope someone can help
thanks
lukeh6n2
Re: FORD TRANSIT CAMPER VAN 2.0 PINTO COLD START
Postby ricc » Mon Mar 06, 2017 9:41 am
quick answer is a diesel conversion ..... or someone to buy the thing so you can buy a diesel one.
longer answere
last one i had was an 80ish mk 2
where to start.... either ignition system or air fuel , get a haynes manual...
clean all the ignition system componants, replace spark plugs and leads with new, does it have a distributor with points that need replacing?,
replace air filter, clean carb or get a new one with a manual choke.
ricc
Postby hornhead » Mon Mar 06, 2017 10:48 am
about normal service for an auto choke vv carb...starts, chugs, ease revs up then just about idle..then as warms settles to fast idle
you could reduce auto choke setting or put a manual choke weber ich34 on 8)
G might be crossover re petrol, look for engine number at rear of block by exhaust manifold...from memory think you lookin NAT for unleaded,don't rely on that...
I had a list somewhere,will try and look later
hornhead
Postby lukeh6n2 » Mon Mar 06, 2017 7:00 pm
Today I had an hour of free time so have had a play
Have fitted a new set of spark plugs seems a bit better but still a bugger to start from cold
See this video with the backfire
https://youtu.be/8_8czMUmOZY
As your see at the start a big puff by the exhaust manifold have seen a big leak so new gaskets ordered from ecp to fit them tomorrow to eliminate any exhaust leaks
Unsure what else to do?
lukeh6n2
Postby gumgum traveler » Sat Mar 11, 2017 7:46 am
hi just saw your video and to me it seems like the timing is out the motor should spin faster than it was so im thinking to far advanced just my thoughts
if it's not broken don't fix it and Don't panic there is always a solution
gumgum traveler
Postby gumgum traveler » Sat Mar 11, 2017 7:48 am
just looked again and saw the flame out of the carby just confirms my thoughts to far advanced need a manual as to correct setting and which way to move the distributor or maybe timing belt wear try timing the distributor first :)
gumgum traveler
Postby robbie.cee » Wed Mar 15, 2017 9:01 am
Too lean and or too advanced... have you tried pumping gas one full pump before turning key ?
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Wed Mar 15, 2017 9:03 am
6° btdc set with vac disconnected and blocked. Mine ran sweet although i put weber 32/36 carb on mine.
Had
MAKE IT FIT
robbie.cee
Postby lukeh6n2 » Sat Mar 18, 2017 7:28 pm
knocked the petrol pinto on the head
managed to find a rotten transit local with a 2.5 di in, 98k on the clock
this week has been busy, had to change the whole dash & loom but shes in and running
pictures for you guys
http://imgur.com/GTwrhnu
http://imgur.com/BmyLSp1
http://imgur.com/Wy3rilo
lukeh6n2
Postby robbie.cee » Wed Apr 12, 2017 1:11 pm
Well done mate!
Had
MAKE IT FIT
robbie.cee
