smoke on startup, mk5 non turbo '97
Postby crystalvoyager » Sun Mar 19, 2017 9:18 pm
hi folks, can anyone tell me any possible symptoms for the problem my van has developed - i'm getting a puff of smoke on start up. the van runs ok the rest of ther time. I've disabled the egr years ago. would it be ready for an injector service. or something more expensive. cheers folks
crystalvoyager
Re: smoke on startup, mk5 non turbo '97
Postby Altransit » Mon Mar 20, 2017 2:51 pm
There could be a few different reasons; has it had a service inc. new filters, and has it had a new timing belt :?:
Postby crystalvoyager » Mon Mar 20, 2017 6:50 pm
yes its had a belt and water pump a couple of thou ago and i keep the filters and oil sparkling
crystalvoyager
Postby gotgcoalman » Mon Mar 20, 2017 9:09 pm
Excecessive fuel in exhuast due to cooler weather cranking or valve stem oil seals.
Oil in the inlet?
The list is almost infinate even on these simple engines.
Too bloody quiet :shock:
gotgcoalman
Postby gumgum traveler » Tue Mar 21, 2017 7:05 am
Hi if you start and let run for a while turn off and then start again does it still puff out smoke if not it sounds more like oil leaking past the valve guide seals over night just my thoughts
if it's not broken don't fix it and Don't panic there is always a solution
gumgum traveler
Postby crystalvoyager » Tue Mar 21, 2017 8:29 pm
I've only noticed it the other day and it was hot at the time. there was a puff of smoke every time i fired it up.
crystalvoyager
Postby gumgum traveler » Tue Mar 21, 2017 11:11 pm
mm i would leave it you could chase it and still never know but i still think its valve guide seals but that just my thoughts :)
gumgum traveler
