air vent
air vent
Postby gumgum traveler » Wed Mar 22, 2017 6:24 am
Hi all i might be a novice about it but why does my mk5 1999 have a air cleaner vent on the outside passenger guard and the one i brought mk5 1998 does not same motor turbo duel batts all the same and i have not noticed any others :? :? :?
i know its not imperative to the workings i would just like to know
if it's not broken don't fix it and Don't panic there is always a solution
gumgum traveler
Re: air vent
Postby robbie.cee » Wed Mar 22, 2017 8:26 am
Different panel then for non turbo. Tourneos had em but not all td!!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Re: air vent
Postby robbie.cee » Wed Mar 22, 2017 8:27 am
Sorry should have said non tourneo
Had
MAKE IT FIT
robbie.cee
Re: air vent
Postby Altransit » Wed Mar 22, 2017 2:29 pm
Do you mean the triangular one on the passenger wing :?:
It's only there if you have auto plus aircon, or intercooler plus aircon, or auto plus intercooler (I think!) 8)
Re: air vent
Postby Mfr » Wed Mar 22, 2017 7:31 pm
Mine doesn't have air con or auto but does have the air vent, intercooled turbo 115 ps
Mfr
Re: air vent
Postby gumgum traveler » Thu Mar 23, 2017 12:42 am
mm the spare one i have has air con but a different configuration on the turbo inlet manifold maybe after market turbo might have bean a non turbo in a past life :wink:
gumgum traveler
Re: air vent
Postby MinorMatt » Thu Mar 23, 2017 11:20 am
Intercooled (115PS) have them and aircon (from 96 onwards) vans have them.
Some people like them and retro fit to others
Gearbox is irrelevant.
You can't have factory aircon and intercooler (because the intercooler gets in the way of the aircon condensor rad)
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: air vent
Postby derv23 » Fri Mar 24, 2017 3:43 pm
Yup I have a TD tourneo with A/C with the vent and a non TD with A/C without the vent, though it has had new wings in the past so no idea if it had one originally. HTH.
MK5 Tourneo.
derv23
Re: air vent
Postby aussieboy » Sat Apr 08, 2017 1:08 pm
I have two 190 cab chassis 2.5 turbo diesel 100bhp non intercooler models. As Matt stated further up as both mine have air con both have the vent in the n/s wing. I have however serviced two vans that were also turbo'd - 99% of them here are Turbo and 99% have air con too and neither had the air vent in the wing - it is possible though that these vans had been repaired using the non vented wing as there are loads of the DOHC Petrol models in Both the van and cab chassis models which dont have the vent !
aussieboy
