Just got myself a Mk5 SWB and fixing a few bit's on it.
One problem I have is that the air blower works in the cab on all settings, so not the resistor problem.
But the air is totally cold, never comes off cold no matter what setting I have it set to or how long I have been driving.
Temp on gauge says between a third and half heat after a few minutes driving.
I'm thinking maybe back flushing the cooling system with a jet wash may help. Does that sound worth while? Any other ideas / known problems for this?
Could it be a heater control valve. Where is it located and is it an easy job to replace?
Any help in the right direction would be greatly appreciated.
