gotgcoalman wrote:hole blocked by plate = blanked off.
On a mk5 they cause more problems than they are suposed to cure.
here's a plate i made a while ago to fit to mine.
Low speed and black smoke..........
Too much fuel and not enough air to complete the combustion process.
Check your air filter isn't full of nasties and blocked.
When was it last serviced?
oil / filter change,fuel filter and air filter.
Valve clearances as well.
Inlet manifold might be full of nasty black EGR stuff.
just a few things to think about.
CamperVanBeethoven wrote:Uh very low speed and black smoke?
I had that happen and it had an easy solution ... thankfully.
Does it run fine at idle, but as you increase the throttle, it sounds like the WORST case of 'pinking' you ever heard, accompanied by lots of black smoke and no power? Can't get past about 1,000 revs?
Even though the EGR has been blanked off there may still be a rod going to a throttle butterfly on the intake. It connects from the diesel pump via a rod to an actuator on the side of the air intake ... as you increase revs, the butterfly opens. If the actuating lever falls off, you will get the symptoms you describe. The rod goes from the diesel pump to this butterfly valve. Even if EGR was blanked off the rod may have been left in place (instead of the butterfly valve being tied up to fully open position) so that there's no external sign the EGR was tampered with.
If the butterfly fails to open you get far too much fuel and far too little air ... leading to lots of black smoke and no power
PS Welcome to the forums
rebuilder86 wrote:Perhaps the issue is that the electronic sensor on the EGR valve will tell the ECU that the EGR isnt activiating, but in my opinion thats a good thing as mapping will be adjusted to compensate, leading to an increase in power, but maybe a decrease in economy.
rebuilder86 wrote:yes confused as to why ppl blank off EGR valves.
gotgcoalman wrote:Have you ever had to clean an inlet manifold?
