Fuel injection pump
Fuel injection pump
Postby rolo.m » Sat Apr 15, 2017 11:47 am
Needed urgently ford transit mk5 SWB80 TD automatic turbo fuel injection pump
DSA 1096
serial number 12212H0G
model 8720A011A
please call 07504214151
I am in Colchester
This is my autism project van and it needs to be back on the road asap the local garage has it-they put new seals in but it is still leaking profusely around the same area
rolo.m
Re: Fuel injection pump
Postby gotgcoalman » Sat Apr 15, 2017 11:55 am
post what the problem is with the pump (lucas?)
someone clued up on the turbo pumps will be able to give advice.
you may be able to repair it and not need a replacement .
Too bloody quiet :shock:
gotgcoalman
Postby rolo.m » Sat Apr 15, 2017 12:15 pm
The local garage can't fix it-they have put in new seals-the guy knows diesel pumps-does being an automatic have any bearing on getting a new pump? right now my van is at the garage with half and is going nowhere until it's fixed :(
rolo.m
Postby gotgcoalman » Sat Apr 15, 2017 3:42 pm
it narrows your options down a bit :(
It's a leak not electrical?
gotgcoalman
Postby rolo.m » Sat Apr 15, 2017 5:03 pm
it's definately a bad leak-two drops a second-its a failed Mot
rolo.m
Postby MinorMatt » Sat Apr 15, 2017 8:05 pm
You Don't need a DSA1096, an 1191 or 1190 would also work.
Automatic has no odds on the Pump.
I have a Pump which I have not checked but is reportedly good (except the Stop Solenoid Plunger needs changing - which I will Do with a genuine lucas/delphi part). Off the top of my head it's a DSA1191
If that's of interest let me know...
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby rolo.m » Tue Apr 18, 2017 1:55 pm
hi is it a turbo pump? if so and it will fit yes please-i have just been ripped off already so am really unsure-my project is now at a complete standstill
my reg is P112NLF please double check-my phone number is 07504214151-my project is autismrolo which I use the van for-it is an information center
rolo.m
Postby rolo.m » Tue Apr 18, 2017 4:35 pm
On reflection please do not find solenoid- I have taken the pump to a specialist-too many dramas and too many peoples contradicting opinions-Thanks though
rolo.m
Postby MinorMatt » Tue Apr 18, 2017 6:39 pm
Ok no issues.
Just found a DSA1096 I had forgotten about which I am pretty certain is good too.
I would normally check them out before offering but due to severe lack of space I can't right now
93 L GL Minibus
Postby rolo.m » Wed Apr 19, 2017 2:34 pm
Hi-need 1096 model 8720A011A-the diesel specialist has said no other will work on my van
rolo.m
Postby twin wheel camper » Wed Apr 19, 2017 6:12 pm
Hi bud just a little heads up,minor Matt on here really no's his onions when it comes to these epic pumps so any advice he gives take note because he isn't full of sh*t unlike plenty of others on Internet forums, not saying you aren't talking his advice but most diesel specialists no next to nothing about these pumps because there weren't very common even in the days when they were sold new!!!!
So if you want to no if a pump will work on a certain engine look no further :D
twin wheel camper
Postby rolo.m » Thu Apr 20, 2017 9:51 pm
Thanks for the concern but the diesel specialist has found me what I need-they are taking the old one to keep the costs down-The other person who ripped me off sent me a pump knowing it would not be compatible-not only that it arrived completely black with no ID plate so no idea which model or which dsa-I will never deal with anyone online again unless they are local and I know they have impeccable credentials-I was desperate for a solution and yet another lying SOB took me and my autism project for a ride..
rolo.m
Postby Altransit » Thu Apr 20, 2017 10:01 pm
If you're ever in any doubt about who you can trust for advice (and parts) on here, just PM me, or any of the other moderators, and we can advise on who is 100% trustworthy, (like Matt), or who is possibly an unknown quantity.
A lot of us have had dealings with a lot of other members and know who is who :)
