MK5 Transit 190 Turbo Diesel Diff Ratio
Postby aussieboy » Sun Apr 16, 2017 1:14 pm
I have a couple of Cab Chassis 190 2.5 Turbo Diesels, twin rear wheel model with the 5.11 diff ratio fitted from new -which i find causes too many revs and also additional fuel used when driving at about 70mph/110kph and with a lot of long distance driving planned i would really like to address this if I can. what are the other options available to me to reduce the revs at speed ? if I change the diff does anyone know which speedo drive is also required and lastly which model Transit is a different ratio diff fitted too for me to source a second hand unit from ? Thanks in advance
aussieboy
Re: MK5 Transit 190 Turbo Diesel Diff Ratio
Postby twin wheel camper » Sun Apr 16, 2017 2:50 pm
It has to be off a 6 stud axel and unless you get it professionally fitted needs to be a complete axel change, you can fit the diff from a single rear wheel to your axel but it is really a professional job to set it up correctly.
The diff you have will be 5.14 the only lower ratio diff available for your 6 stud is 4.63 and over here pretty hard to get as most were the same as yours a 5.14 ratio for pulling the extra load of the six stud is allowed to pull.
twin wheel camper
Postby Jim Archer » Sun Apr 16, 2017 7:50 pm
Try looking for minibus axles.
I believe some of the early Mk6 RWD models used the same axle.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby vanfox » Mon Apr 17, 2017 10:31 am
Add overdrive?
vanfox
Postby V184 » Mon Apr 17, 2017 12:13 pm
vanfox wrote:Add overdrive?
Not strong enough its a Turbo, n/a di s used to kill them :( easiest way buy a cwp if you cant find a complete axle :wink:
V184
Postby Mfr » Mon Apr 17, 2017 12:32 pm
Yes, you can get them from transit parts uk.
I got a 4.63 from a tipper in a scrappy and then when I was getting my gearbox rebuilt I got them to change out the 5th gear from a 0.82 to a 0.75 (Scorpio mt75)
The change from 5.14 to 4.63 got me from 3600rpm @ 70mph to 3250rpm. Then the 5th gear got it down to 3000rpm @ 70mph. Or to put it another way, like having a 4.21 CW&P. I am convinced that other CW&P's are out there that will fit but never had the money to try.
One gearbox and axle guy I spoke to said that some 4x4 county's had a 4.11 made for the 6 stud axle but I have never seen one.
Mfr
Postby Mfr » Mon Apr 17, 2017 12:33 pm
Jim Archer wrote:Try looking for minibus axles.
Jim
Mfr
Postby aussieboy » Mon Apr 17, 2017 3:48 pm
thanks for the replies. does anyone know which gear is needed for the speedo drive if i switch to a 4.6 diff to give the correct speedo reading ?
aussieboy
Postby Mfr » Mon Apr 17, 2017 4:25 pm
I found the 22 tooth yellow speedo gear gave me a perfect reading identical to the satnav. 22 tooth Yellow gear number 7230066 (for electronic speedo)
viewtopic.php?f=4&t=165526
Mfr
Postby vanfox » Mon Apr 17, 2017 5:58 pm
Not strong enough its a Turbo, n/a di s used to kill them . Wrong.
Drivers and duff solenoids used to kill them, they don't like reverse. The J type in mine easily handles the TDi. Quite easy to fit.
vanfox
Postby vanfox » Mon Apr 17, 2017 6:00 pm
vanfox
Postby V184 » Mon Apr 17, 2017 7:00 pm
If the Solenoid fails 99% of times the overdrive wont engage, occasionally it would be stuck in overdrive but very rare for this to happen.
They used to be fitted with inhibitor switches which prevented overdrive being selected in reverse. One sign of the overdrive failing was when you reversed it felt like you had clutch slip :o They didnt give as much trouble in the 2.0 or 3.0 v6 petrol
V184
Postby karl » Mon Apr 17, 2017 7:10 pm
Jim
No they use the same internals
Crown and pinnion only the whole axle will not fit
I have a 4.63 in my van from a mrk 5 twin wheel axle
karl
Tranny Lover!!!
Postby aussieboy » Wed Apr 26, 2017 1:17 pm
Thanks for the link to your post MFR - gives me a few part numbers to try - my cab chassis has 185/15 fitted at present (original size) but I am switching to 195/15 8 plys as they are easy to get here and way cheaper too
aussieboy
Postby Mfr » Wed Apr 26, 2017 9:17 pm
aussieboy wrote:Thanks for the link to your post MFR - gives me a few part numbers to try - my cab chassis has 185/15 fitted at present (original size) but I am switching to 195/15 8 plys as they are easy to get here and way cheaper too
No worries, hope you get the right one. Living near the A9 with its average speed cameras you soon make lots of enemies driving at 45mph so I thought it was best to get as close the the real 50mph as possible. Although you still get trucks behind wanting to do 60mph :roll:
Mfr
