Hi all ok quick question i am sure this is a common fault but cant find any info i need.
So the situ is i have a 1998 100 2.5 di with type 2 sliding pin type calipers, the stupid bottom torx bolt that holds slider to the anchor bracket was well and truly stuck in there i eventually got it out but need a new one any body got a part number for it or would you be able to just use a std hex head bolt the same length and diameter etc.
