by ozzy69 » Mon Apr 17, 2017 7:59 pm
Hello ,i have just got my self a 2.5 ldv turbine engine but its missing two injectors ,codes are (974f-fa 32148m97) but looking on the bay and there injectors for turbo di's are different codes but do show as 100psi blue spot but my other two are brown spot ? can i mix and match as long as the are 100psi injectors ? also what else needs changed to make the ldv fit my transit ie will i need to swap engine mounts,clutch,flywheel etc
