Hi
I will be driving my mk3 to southern Spain and back in July and need to sort out my gearbox as it jumps out of gear. I've had some quotes to refurbish my existing box with new gear set, bearings and seals etc and am looking at about £420 plus cost of dropping and refitting box. The other option is changing cross member and prop and then fitting the mt75 (not sure of cost yet)
What would you guys do?
And if you think upgrading is better then can anyone recommend a mechanic in Suffolk who would be up for doing the job?
