Old question - sorry!
Postby tuk841 » Tue Apr 25, 2017 11:14 am
Hello - I'm new to the forum! Bought a restored 1997 120 low-roof ex BT panel van last autumn via a seller on ebay. Runs well and I'm enjoying it.
I'd like to add some bling and up the gearing some (8-10%) so am looking at alloys. I have read all the threads and there seem little choice when they written and virtually no choice now.
I can see ebay is awash with mk6/7 5x160PCD wheels. I read that these use the hub to centre unlike the mk5 that uses its studs.
So my question is:
What does this mean on the ground? - can mk6/7 alloys be modified to fit or the hubs on the mk5 altered?
Thanks very much in advance for any help, and apologies again for raising the subject which I have no doubt has been done many times before (but maybe not recently?)
tuk841
Re: Old question - sorry!
Postby MinorMatt » Tue Apr 25, 2017 7:31 pm
Counterbore the bolts holding the front discs on and fit cap heads.
Get a 60 degree countersink and countersink the wheel nut holes.
Use car/mk5 alloy wheel nuts
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby tuk841 » Fri May 05, 2017 7:14 pm
Thanks very much for that Matt! - so I have gone ahead and bought a set of 6.5J x16 steels from a newish van, delivered today, similar to eBay item number:222014958085
Just taken taken off a front wheel for inspection - if I understand correctly I have to remove the disc bolts and counter-bore each hole to allow capped bolts to drop-in flush - may I ask if you have done this and if so any pics? is there enough material around the holes? and would you have a spec on the cap-head bolts please?
tuk841
Postby MinorMatt » Sat May 06, 2017 1:49 pm
I haven't personally but Luke has.
Pull one bolt out and measure its length, you just need a caphead the same lengthx
93 L GL Minibus
