valve stem oil seals - mk5
Postby crystalvoyager » Tue Apr 25, 2017 10:52 pm
Hi folks, can anyone give me a heads up about replacing the valve stem oil seals on the mk5? Any things to watch out for. Not looking forward to it but got to be done i think
crystalvoyager
Re: valve stem oil seals - mk5
Postby vanfox » Wed Apr 26, 2017 12:42 pm
Why?
Somewhere in the dim and distant past I recall it being possible to hold the valve up with the piston whilst changing the stem oil seals. Cam belt off and piston at TDC. Someone?
There is a tool to do the Pinto, had mine done, maybe just an old man being confused.
vanfox
Postby crystalvoyager » Wed Apr 26, 2017 10:04 pm
i got a plume of blue smoke in the morning when i fire it up, the smoking peters out after a few seconds.
is there anyone out there who has changed the seals on a DI without taking the head off able to give me a run down how to do the job please.
cheers folks
crystalvoyager
Postby V184 » Thu Apr 27, 2017 12:04 pm
we used to use a petrol (pinto) valve spring remover. You dismantle the rocker shaft & lever under it with the tool. Are you sure the seals are knackered ?
V184
Postby crystalvoyager » Thu Apr 27, 2017 10:25 pm
no I'm not sure but like i say the symptoms look likely, do you think it could be something else
crystalvoyager
Postby Frag » Fri Apr 28, 2017 6:46 am
Is your van N/A or turbo ?
Oh,and this may be of interest;
viewtopic.php?f=4&t=34558
Frag
Ford Technician
Postby crystalvoyager » Fri Apr 28, 2017 9:56 pm
its a n/a. i keep the filters and oil clean. everything else seems ok. just a plume of smoke on cold star.
I've had a look at that post yeah thanks, most of the photos are missing so i can't get a handle on what the special tool looks like.
so if i set the timing at tdc i can do cylinders 1 and 4 then turn the pulley so the mark has travelled 180 deg and the i can do 2 and 3? is that right.
if i saw what the tool looked like i could probably make it.
crystalvoyager
Postby Frag » Sat Apr 29, 2017 9:18 am
Since that earlier thread,I now have the genuine special tool for doing the seals in situ,I'll get you some pics and dimensions,or if need be I'll lend it you to do the job.
If your is N/A is it the 70ps or 76ps 'banana' engine ?
What year van ?
Frag
Ford Technician
Postby crystalvoyager » Sun Apr 30, 2017 12:45 am
its a '97 70ps
thanks a lot, photos and dimensions would be a great help.
I'm about to take it off the road to replace the front cross member so i can get the seals done at the same time
thanks again
crystalvoyager
Postby crystalvoyager » Tue May 02, 2017 9:59 pm
aright frag, did you get the dimensions of that valve tool by any chance.
cheers
s
crystalvoyager
