hiya guys,
my 2.4 di 1998 tipper has started acting up lately.
when i put my foot down it starts accelerating then cuts out for a millisecond, then accelerates again, and just today its doing it quite a bit more.
earlier i parked it front end up on a hill and it was a right biatch to get going, i had to crank it over in gear and get it on the level and eventually it started..
these may be related or totally seperate faults... i did have a feed pipe to the pump wear thru where it was catching a steel pipe and that caused really bad starting but that was sorted.
im more concerned about the cutting out while im accelerating..
oh and also the water system doesnt pressureize and im losing a bit of water altho nothings leaking, i guess its leaking on the head gasket so ive got a head gasket to change along with a timing belt... the cutting out i think is nothing to do with the head,,, but im no diesel guru..
any advice will be greatly appreciated
regards
andy
