epic pump part help please
Postby iank » Mon May 01, 2017 2:30 pm
Well the old girl (transit) has been running sweetly since the fuel cutoff solenoid plunger was replaced (and back to normal :| boost)
Yesterday when we got home I discovered a lot of fuel leaking from the pump.
It looks like it is coming from the bottom of the pump.
There is a small screw plug at the base of the pump. It has a copper type flat washer with a neoprene seal in it.
I think its the culprit (hoping so)
I tried a couple of delphi diesel injection centres in melbourne with out success.
From my exploded view its item 170 and the plug item 171
The pump is 8720B031A and I think the part number may be 7187-112
Can any one please point me to where I can get one please or has stocks.
Ian :oops:
iank
Re: epic pump part help please
Postby Wheelchair7 » Mon May 01, 2017 3:37 pm
iank wrote:Well the old girl (transit) has been running sweetly since the fuel cutoff solenoid plunger was replaced (and back to normal :| boost)
Ian :oops:
Got a pump england UK if u need s spare
Sent from my Obi MV1 using Tapatalk
Wheelchair7
Postby iank » Tue May 02, 2017 4:18 am
Thanks wheelchair7
Good to know that
Pump itself has been fine so just trying to source the washer/o ring at this stage thanks
Ian
iank
Postby DodgeRover » Tue May 02, 2017 11:24 am
Copper washer could be reanneelled (that's spelt wrong sorry) basically you just get it hot then it can be reused.
Is the other one an O ring type seal?
DodgeRover
Postby MinorMatt » Tue May 02, 2017 1:05 pm
have you got a pic showing which part of the pump it is?
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby wazzadj » Wed May 03, 2017 4:36 am
Just my two bids worth has similar issue thought it was same leaking issue after replacing solinoid O rings
but found that the housing was not quiet sitting centered over the O rings properly on the solinoid housing assy and was leaking down and underneath at same point at the screw on the bottom
check re seat the housing might fix issue
cheers
wazza
1994 MK4 2.5DI Auto High Roof Australian Style 1996 2.5 TDI with rebuilt AUTO Bring on the power !!!!
wazzadj
Postby iank » Mon May 08, 2017 4:28 am
Thanks for your help and replies. I managed to source that washer.
However it looks like it is still leaking from a seal somewhere on the low pressure side.
Im guessing its the seal between the two sections.
Pity as the pumps working ok.
Ian
iank
Postby darren.moss.355 » Fri May 12, 2017 8:46 pm
You can get full seal kits on ebay in the UK for these pumps mine was leaking from center bottom of pump iv just tried stripping the pump and fitting new body seals and solinoid seals only now van fires but cuts out
Sent from my SM-N910F using Tapatalk
darren.moss.355
Postby iank » Sun May 21, 2017 1:29 pm
Thanks for the input everyone.
Looking at the pump exploded view that some gave me previously, Looks like its the seal in the body of the pump between the low pressure side and the pump body
unfortunately
rgds
iank
Postby darren.moss.355 » Mon May 22, 2017 8:32 am
Hello iank is there any way you could post the exploded view off the pump please would be very helpfull.
darren.moss.355
Postby wazzadj » Mon May 22, 2017 8:38 am
hey mate i have the full tech manual for this as well
wazzadj
Postby darren.moss.355 » Mon May 22, 2017 1:57 pm
Hi wazzadj is the manual u have a digital copy if so is there any way you could send me a copy please.
darren.moss.355
