weseeyou wrote:thanks for the replies fellas.
I think Matt has it.
The seller claims that it a left hand side lower rear corner panel to fit behind the rear arch on a LWB
Its obvious from the image that it could only fit an ELWB (jumbo) vehicle but he wouldn't have it.
I thought that it might have been intended to fit in front of the rear wheel arch as I have never seen any ELWB panels before.
I know I have it
There is no such thing as an ELWB XLWB etc, its a LWB but with a body extension (correctly known as an extended frame). The longcube, hughcube and standard LWB all have the same wheelbase of 3570mm. Obviously mk3 wheelbase is different.
The seller is correct in that it fits 86-2000 lwb, just not all varients
www.facebook.com/transitionclassicsLucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
