2,5 Di Turbo 1997, engine change, electronic problems?
Postby matthias » Thu May 25, 2017 8:30 pm
Hi,
unfortunaltely the cam belt of my Turbo "snapped" (see another post), so I possibly need to change the engine.
Got already a complete spare van of the same year of manufacture, but a few month later.
Will I need to change the ECU after the installation of the new engine, or in other words, does the new engine work with the electronics (ECU) of my car?
And another: I possibly change the engine complete with the MT75 gearbox, but the one of the donor car has an electronic speedo, so the speedo "pick up" of that gearbox must be different to mine (with speedo cable).
Can I use the new gearbox (think so)?
Thanks!
Matthias
matthias
Re: 2,5 Di Turbo 1997, engine change, electronic problems?
Postby vanfox » Thu May 25, 2017 8:49 pm
If you're lucky, remove and straighten any bent pushrods, fit new belt and time engine, refit pushrods, reset the clearances and all should be well. ..so I'm told.......
vanfox
Postby matthias » Thu May 25, 2017 9:35 pm
vanfox wrote:If you're lucky, remove and straighten any bent pushrods, fit new belt and time engine, refit pushrods, reset the clearances and all should be well. ..so I'm told.......
I did so, repalced the push rods, but the engine seems to have no compression and does not start, so I`m ressuming that the valves are also damaged.
matthias
Postby robbie.cee » Sat May 27, 2017 11:36 pm
Gear box should cayer fpr electronic speedo one side and cable on other side (right)
Sent from my SM-G920F using Tapatalk
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby matthias » Sun May 28, 2017 1:26 pm
I was lucky!
After fitting "new" pushrods (from my 95 Transit with 76 PS Banana-engine) and adjusting the valve clearences (what I fisrt didn`t!), everything seems be ok.
Thank you!
Matthias
matthias
Postby matthias » Sun May 28, 2017 1:30 pm
robbie.cee wrote:Gear box should cayer fpr electronic speedo one side and cable on other side (right)
Thank you!
(But I got my old engine with the bended pushrods (after snapped cam belt) running again)
Matthias
By the way:
If my Transit would be of better condition I would have a further thinking of an 2,9 Cosworth conversion...... (still have "a few" of these) ;-)
matthias
Postby robbie.cee » Sun May 28, 2017 3:48 pm
Any spares i could use on my 2.9? Need vac canister and vac solenoid and any vac related pipes for egr and vis valve as my bob is currently wored to boa loom and no vis/imrc or egr functioning at present
Had
MAKE IT FIT
robbie.cee
Postby MinorMatt » Tue May 30, 2017 2:00 pm
For future reference...
If you fit a turbo engine from a mk5 into another mk5 - you don't need to swap ECUs or anything like that. Nothing on the engine is coded
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby gotgcoalman » Tue May 30, 2017 11:06 pm
MinorMatt wrote:For future reference...
appart from number plate screws :lol:
Too bloody quiet :shock:
gotgcoalman
