ahhhhggg epic fail
ahhhhggg epic fail
Postby dyte2004 » Thu May 25, 2017 8:44 pm
Ah the return of the epic,not had any problems for a year but today the wife broke down [99td]at first she cut out when slowing for a speed bump with engine light and she told me she had no power so limp mode,when I got to her it was the same but after a few starts the light would go out and the idle would rise to 1500-2000rpm and some times it just revs its self but not high rpm just like short burst as if you were blipping the pedals but it did go back into limp mode more the once as I nursed it home cant get a pump here in France does anyone have a blue dot good epic or all the bit for a Bosch swap ,is it with just trying the pedal first if so does anyone have one ,please helpppp me lol we want to go on lollipops [motorhome],maybe minormatt has them in stock if so please pm me
dyte2004
Re: ahhhhggg epic fail
Postby dyte2004 » Sat May 27, 2017 7:27 pm
Ok so update had the chance of a cheap epic from a running van fitted it and all seems good haven't tried on the road as I reused the old belt will order a belt in the week fingers crossed eh
dyte2004
Postby dyte2004 » Sat May 27, 2017 7:47 pm
Just one question the replacement pump was much tighter to turn by hand than the old one ,I could almost spin the old one by hand could this have been its problem
dyte2004
Postby MinorMatt » Tue May 30, 2017 2:03 pm
Sorry, I have been otherwise occupied!
Sounds like symptoms of the rotor failing tbh, so it would have been new pump time whatever.
I think this failure (along with cam failure) is down to less lubrication in modern diesel and I think that adding 2 stroke is a very good idea on the EPIC
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby MinorMatt » Tue May 30, 2017 2:06 pm
93 L GL Minibus
Postby dyte2004 » Wed May 31, 2017 9:37 pm
All seems ok, I put a new belt on today and took it for a run all seems good so fingers crossed I got lucky with the used epic pump if I had to moan it would be that the idle is very very slightly low but I believe that is only adjustable when plugged in the a lucas laser
dyte2004
Postby dyte2004 » Fri Jun 02, 2017 1:43 pm
My egr is blanked at the inlet side ,can I blank the other side and remove it all together or does it need to stay plugged in ?
dyte2004
