Hi,
think it`s a bigger disaster, see foto.
It happened at low speed (2o miles?) and because I needed to get the car out of that zone, I tried to move the car afterwards by the starter, until it blocked completely (clever?)
Because I`m thinking that the engine is to much damaged, I already planned to swop the engine to another one (see other topic), but thought it`s possibly worth a try to look under the valve cover, and saw these badly bend push rods.
So I took the puh rods out of my 95 High Cube with "banana-engine" to try a repair, but the engine didn`t start and seems to have no compression.
With such a damage, will it be likely that also the valves are bend?
(Unfortunately I don`t have a diesel compression tester).
Thanks!
Matthias
