Mk 5 minibus floor!
Mk 5 minibus floor!
Postby transit-town » Fri May 26, 2017 11:15 pm
Hi folks, i have stripped a 99 mk5 of its seats in the back but where the seat brackets were is normal floor but the rest of the floor is coated in some sort of rubber seal which was under the floor mat, question is how do i not know there is rust under it as it's impossible to remove? Cheers.ImageImage
transit-town
Re: Mk 5 minibus floor!
Postby focusp » Sat May 27, 2017 7:35 am
its soundproofing
scraper hot air gun and lots of effort with flap wheels or wire brush in grinder will remove it :D
focusp
Postby bigjohnthomas » Sat May 27, 2017 7:55 am
While rome burned
Hrh
Allcock
bigjohnthomas
Postby vanfox » Sat May 27, 2017 8:45 am
Agree, hot air gun and a knotted wire brush in grinder will move it once softened.
Health warning!!! The knotted wire brush will go straight thru' jeans, boiler suit and skin.......
vanfox
Postby CamperVanBeethoven » Sat May 27, 2017 8:49 am
vanfox wrote:Agree, hot air gun and a knotted wire brush in grinder will move it once softened.
That sounds like the voice of (painful) experience!
CamperVanBeethoven
Postby ricc » Sat May 27, 2017 10:10 am
would it not be best to look underneath?
slap underseal over any signs of rust so the mot tester cant see it and jobs done.
ricc
Postby Keef » Sat May 27, 2017 10:17 am
It's unlikely to have rust under the soundproofing if it's still sound, that stuff sticks like sh*t to a blanket so moisture won't be getting in there.
You're far more likely to get rust starting from the other side of the floor (ie. underneath the van) because the crap they used underneath tends to crack and let the moisture get behind in it.
Personally I'd spend the effort under the van.
Keef
Postby transit-town » Wed May 31, 2017 11:32 pm
Sound lads,underneath looks fine as it's been shultz in the past by someone else
transit-town
Postby vanfox » Thu Jun 01, 2017 12:27 pm
Trouble is Shultz won't stop a testers' probe/toffee hammer from finding corrosion.
vanfox
Postby paulkidstransit » Sun Jun 11, 2017 8:02 am
large chisle and hammer,it will come of in large chunks, anything left use the grinder, very messy job, most cars /vans got this coating, make sure everything is covered up its a messy job!!!
paulkidstransit
