P reg transit failed MOT - Worth repairing, advice on costs
Postby jaycey001 » Sat May 27, 2017 12:32 pm
Hi
I have a Transit Minibus that has failed its MOT, its got around 121k on the clock and runs and starts perfectly, even after standing for a few months. Unfortunatly it has failed its MOT, Last year I had a substantial amount of welding done and was hoping it would be ok (ish) this year.
The garage have quoted between £400-500 to have the following work done (which i think is very high so will probably seek out another garage to do the work.
My question though is if we keep the minibus we will then be investing in to it, and will be keeping it long term. I was thinking a good rust converter underneath along with a healthy coat of waxoyl would give me a few more years service but what do you guys thing? Is it worth fixing up and spending the time and money on or should we cut our losses and find something else?
The bus itself is quite solid on the body work front, back doors a bit scabby and front OS arch has a bit of rust but other than that its quite presentable and would need minimal body work... its just the advisory "Vehicle structure in poor condition" that worries me a bit....
I would be great full of your input
Many Thanks
James
Reason(s) for failure
Nearside front brake binding (3.7.B.1)
Nearside Front Brake hose ferrule excessively corroded (3.6.B.4e)
Exhaust has a major leak of exhaust gases down pipe (7.1.2)
Vehicle structure excessively corroded within 30cm of towbar mounting rear cross member (6.6.6)
Offside Front Tyre has ply or cords exposed (4.1.D.1b)
Advisory notice item(s)
Headlamp deteriorated but light output not reduced both lenses cloudy (1.7.5a)
Offside Rear Tyre worn close to the legal limit 3mm (4.1.E.2b)
Oil leak ()
Battery loose but not insecure
Front lower cross member corroded
jaycey001
Re: P reg transit failed MOT - Worth repairing, advice on co
Postby gotgcoalman » Sat May 27, 2017 1:11 pm
Couple of options
spend £500 to keep a van you know to be mechanically sound on the road .
or
use the £500 to go towards another van (buying someone elses problems)
Nearside front brake binding (3.7.B.1) free pistons/guide pins off
Nearside Front Brake hose ferrule excessively corroded (3.6.B.4e) clean up and apply grease or change the flexi if it is really bad
Exhaust has a major leak of exhaust gases down pipe (7.1.2) check gaskets/get it welded/put new 1 on (they dont last forever)
Vehicle structure excessively corroded within 30cm of towbar mounting rear cross member (6.6.6) in with the £500)
Offside Front Tyre has ply or cords exposed (4.1.D.1b) :shock: :shock: :shock: :shock: :shock: :shock:
Headlamp deteriorated but light output not reduced both lenses cloudy (1.7.5a) mild cutting compound sorts these or change for glass ones
Offside Rear Tyre worn close to the legal limit 3mm (4.1.E.2b) :lol: :lol: :lol: :lol: :lol:
Oil leak () don't they all
Battery loose but not insecure hmmmmm secure it
Front lower cross member corroded in with the £500.
Vehicle structure in poor condition major stuff in with the £500.Cosmetic stuff you can sort yourself
So welding done for £500 (seems really excessive for whats listed IMHO)
Tyres and exhaust are consumables anyway.
brakes/pipe just need TLC.
Too bloody quiet :shock:
gotgcoalman
Postby vanfox » Sat May 27, 2017 3:49 pm
Option 3: Buy a mig and learn to weld. Sounds like you had a lot of welding done last year, shame to waste it after one year.
A quote of £500+ sounds like they don't want to do it, too much faffing about and all underneath.
vanfox
Postby ricc » Sun May 28, 2017 9:51 am
so it will cost 500 to get a years mot.
or you can buy another van.... easy spend 2k then find another 500 of similar problems..... and anything much newer will have loads of electrickery to go expensivly wrong.
ricc
Postby bigjohnthomas » Sun May 28, 2017 10:10 am
Tramps nest
Scrap it :D
Hope this helps
Allcock
bigjohnthomas
Postby gotgcoalman » Sun May 28, 2017 5:12 pm
bigjohnthomas wrote:Tramps nest
Scrap it :D
Hope this helps
Allcock
coming from the man with............
an abduction cage and rape tape dispensor in the back of his vans. :shock:
I'll bet the "glove box" is full of the longer Aldi tie wraps :D
gotgcoalman
Postby bigjohnthomas » Sun May 28, 2017 5:53 pm
Not much in the glove box really
Just this stuff
bigjohnthomas
Postby INTRANSIT » Sun May 28, 2017 7:08 pm
If it is reliable and running well spending £500 every year would be well worth it.
Mk7 2.2 85ps Fwd 2008 poverty spec
INTRANSIT
Postby bigjohnthomas » Sun May 28, 2017 7:30 pm
Yes but how much is it going to cost to bodge it next year £1000? £10000000?
Rust will win in the end
I'll give you five quid for it :P
Cash
Delivered
bigjohnthomas
Postby transitjack » Sun May 28, 2017 11:30 pm
thats not an mot failure its just a day in the life of an old transit
are we not men
just get it done man :)
formerly babystepside
transitjack
Postby bigjohnthomas » Sun May 28, 2017 11:51 pm
transitjack wrote:are we not men
We are devo :)
https://youtu.be/hRguZr0xCOc
bigjohnthomas
Postby CamperVanBeethoven » Mon May 29, 2017 12:21 am
We are devo :)
Haha! That's what I thought of too when I heard 'Are we not men?' :)
I sunk far too much money into welding. £500 is f*** all.
This is a better quality version...
https://www.youtube.com/watch?v=5JdS-sSKsBc
CamperVanBeethoven
Postby CamperVanBeethoven » Mon May 29, 2017 12:32 am
CamperVanBeethoven
Postby gotgcoalman » Tue May 30, 2017 12:28 am
We are devo :)
hmmmmmmm
thought you ment devo not deviant :roll:
https://www.youtube.com/watch?v=j_QLzthSkfM
gotgcoalman
