MK5 smiley 2.5D turn key dead as then after a few min starts
Postby 97transit2.5D » Fri Jun 02, 2017 11:45 am
1. turn key partially..heater comes on then off..normal
2. turn key to complete ignition cycle...no starter no engine...quiet.
3. wait few minutes ....turn might then start.
fact batt...fully charged 1yr old
poss earth could be prob.clamps on batt are solid no movement.
where are the main earth chassis connectors on these vehicles???
model 190 2.5d 1997 hicube custom transit..smiley
cheers
97transit2.5D
Re: MK5 smiley 2.5D turn key dead as then after a few min st
Postby Keef » Fri Jun 02, 2017 11:50 am
What does the PATS light do when it won't start?
Keef
Postby Aardvark » Fri Jun 02, 2017 4:27 pm
The battery cables being "solid" means nothing. Loosen both ends of both cables and take them off. Then scrub the terminals and cable lugs clean with a bit of abrasive or wire wool. Pop them back on and if it still doesn't kick the starter into life think about solenoid connections, etc. I replaced ALL my cables and starter wires and it starts better now than it ever did before. Just barely visible corrosion everywhere. It all adds up.
Learning to love rust.........
Aardvark
Postby robbie.cee » Fri Jun 02, 2017 7:08 pm
Worn ign switch?
Sent from my SM-G920F using Tapatalk
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby 97transit2.5D » Sat Feb 17, 2018 10:30 am
see my next post....it must be the starter ...ie solenoid...
97transit2.5D
Postby cherniy_chack » Sat Feb 17, 2018 5:00 pm
When the starter is turned on, the starter does not turn on and the lamps on the instrument panel go out?
After a while, does the starter turn on?
Bad wire contact with battery or bad wires.
cherniy_chack
Postby cherniy_chack » Sun Feb 18, 2018 8:08 am
If the starter does not turn on when the key is turned to the "Start" position, the solenoid does not click, the possible cause of the fault is a critical wear of the starter brushes.
It is necessary to remove the starter and replace the brush panel.
It's simple.
cherniy_chack
Postby ricc » Sun Feb 18, 2018 11:04 am
if the solenoid doesnt click theres no electricity going to the brushes. so not worn brushes.
hotwire the starter ... conect a wire to thesmall signal terminal on the starter solenoid, dab it onto the battery pos, starter should work . youve bypassed the ignition switch and wiring. so the fault is in there somewhere.
if the starter doesnt attempt to work its , its either faulty solenoid or the big battery leads. if solenoid clicks but starter dont turn its either corrosion on the big contacts in the solenoid or the starter brushes.
ricc
Postby 97transit2.5D » Sun Aug 26, 2018 9:49 am
tried to solve inginition not working by bypassing wire on ignition before security..did not work for me...so step1; found solenoid wire going to starter..tee off that with conector..step2.connect tee off wire one side NO relay contacts...mine is 30A relay..step 2 other end of this NO relay goes to 12v on battery. step3. to energise solenoid relay.one end negative to battery. step4.other end solenoid goes to push button switch and is fed by a fused 12V....
to start...light up ignition cluster with key turn...and then push button..works like a dream
Rick
97transit2.5D
