Djrobin wrote:ceurieusneus wrote:Just for a double cheque...
Took this picture of the lift pump on my Transit 2.5Di "banana" engine...
its not a banana engine, and the bosch pump can suck the diesel by himselfes i thought.
after the weekend i will check the timing belt and maybe do a compression test
the worst case for me is to demontage the cilinderhead and look 4 the valves and pistonrings...
its very interesting for me to know how everything (good) works
i've somebody has a complete good engine then i can do the swap en rebuild my smoking engine and still go traveling
where can i find a compression test? i can you use the tester but need a adapter for the injectors
thx
