gotgcoalman wrote:oil level rising
does the dipstick oil smell of diesel?
if so fuel is getting into the sump.
OR
does the dipstick look white/creamy when you check the oil?
If so water is getting into the sump.
what colour is the smoke and what does it smell like?
ceurieusneus wrote:Can you give us some more information?
Last change of oil?
Normal oil consumption for 1000km?
How diluted is the oil now?
How quick is it diluting?
How many km on the clock (if you know)?
How long doe you have this transit?
What do you know about his history?
Blue smoke comes (normally) from burnt oil
I would check up on (small) diesel lift pump
Greetings from Belgium
vanfox wrote:The oil diluted with 2 Liter diesel, thinning the oil, oil can reach the combustion chamber via piston rings and oil seals on the inlet valves...
Possibly leading to a runaway engine as the oil/fuel mix reaches the combustion chambers.
I'd dump the contaminated oil and filter after fixing the source of the contamination.
ceurieusneus wrote:Just for a double cheque...
Took this picture of the lift pump on my Transit 2.5Di "banana" engine...
