Electrics questions- when I turn my side lights on the full beam light comes on dimly on the dash and the relay starts buzzing then when I turn the headlights on the buzzing from the relay stops but the full beam light on the dash fully lights up? My second problem is that my battery light stays on once the van has started tested battery and alt with a multimeter and all seem good and charging any thoughts, cheers
Fist thing I would do is rattle around with the fuses... Don't know how to describe this in English... Probably there is a bad contact somewhere.
Writing was not invented to look for spelling errors Ford Anglia '62, Mercedes 200 '86, Transit ambulance/camper '88, Mercedes CE300 '89, caravan Puck '75 My ambulance conversion
Update, battery light now goes out with revs but comes on at idle, multi ugly wires are corroded and worn could this cause the battery light comes come on at idle but off with revs?
2 things regulator on alternator stuffed or you need to change your main thick power postive cable that runs between battery and alternator to a heavier guage that should fix the battery charge light issue
1994 MK4 2.5DI Auto High Roof Australian Style 1996 2.5 TDI with rebuilt AUTO Bring on the power !!!!
