My van has started to struggle away from junctions and traffic lights. Hill starts are glacially slow, its top speed seems to have reduced and reduces even more on even the slightest gradient. The van revs fine so long as it is not under any load and once its up to about 10 mph it starts to pull away almost normally.
Its a 97 2.5di 190 which has done 130k and is probably on its original clutch. The clutch biting point has always been quite near to the floor for all of the three years I have had the van. I'm guessing its a clutch problem but I wonder if any of you can recommend a fix or experiment before I start swapping the clutch.
