Smiley won't pull away properly.....
Postby jimllshiftit » Tue Jun 20, 2017 6:15 pm
My van has started to struggle away from junctions and traffic lights. Hill starts are glacially slow, its top speed seems to have reduced and reduces even more on even the slightest gradient. The van revs fine so long as it is not under any load and once its up to about 10 mph it starts to pull away almost normally.
Its a 97 2.5di 190 which has done 130k and is probably on its original clutch. The clutch biting point has always been quite near to the floor for all of the three years I have had the van. I'm guessing its a clutch problem but I wonder if any of you can recommend a fix or experiment before I start swapping the clutch.
jimllshiftit
Re: Smiley won't pull away properly.....
Postby joinerman » Tue Jun 20, 2017 6:42 pm
Doesn't sound like clutch to me, what fuel pump have you got manual or epic ?
joinerman
Postby gotgcoalman » Tue Jun 20, 2017 7:29 pm
97 Di should have a Bosch?
Is the clutch slipping or hard to get into gear?
When was the fuel filter/air filter last changed?
Biting point for the clutch is manual adjustment. :wink:
Too bloody quiet :shock:
gotgcoalman
Postby Altransit » Tue Jun 20, 2017 8:47 pm
My money is on a sticking torque sleeve in the pump, (if it is a Bosch) :)
Postby jimllshiftit » Tue Jun 20, 2017 10:03 pm
Its a Bosch,
Had some dodgy home made biodiesel in it recently, but I drained the tank and replaced the fuel filter and its been fine for about 1000 miles.
What do you reckon I should do now? Anyone got a Bosch pump for sale?
jimllshiftit
Postby Altransit » Tue Jun 20, 2017 10:09 pm
Search out "torque sleeve" on here, you'll have to look back in time but there's a very good 'how to' on fixing a sticking torque sleeve, so you don't need to replace the pump 8)
Postby jimllshiftit » Tue Jun 20, 2017 10:15 pm
Thanks for the pointer.
In order to bring the thread forward a few years its here:
viewtopic.php?f=18&t=45777
Gee, that looks like fun!
jimllshiftit
Postby vanfox » Wed Jun 21, 2017 8:31 am
It's not too difficult. There is a thread in the bottom of the piston where you can screw in a long roofing bolt (?) to pull the piston and sleeve out if it sticks.
vanfox
Postby ricc » Wed Jun 21, 2017 10:55 am
might be worth doing the fuel filter again , your dodgy bio diesel may have loosened some crap in the tank thats come though and gummed up the new filter.
ricc
Postby vanfox » Wed Jun 21, 2017 6:12 pm
Pics of T piston showing bolt for removal.
vanfox
