just fitted a turbo lump and epic loom from a r reg into my n reg smiley. turns over now problem just cant get diesel threw the pump anybody had this problem or know of a trick to get her going
Where are you looking for diesel? Have you got a pipe off the back of the pump or one off the injectors? Some times it can take a while off cranking to get it there, make sure u got a really good battery and it's turning over really well
OK have you tryed undoing the pipes on the back off the pump of still nothing coming out from them try taking the plunger out from esos and then see if you get fuel coming out
