Mk4 epic fault codes
Postby darren.moss.355 » Wed Jul 12, 2017 8:49 pm
Can anyone help please iv gone out and used a paper clip in bottom 2 terminals of socket and counted the flashes of eml can anyone help find out what these codes are.
1224
1633
5554
2223
3442
4135
4511
Any help please I think iv got them in the right order.
Sent from my SM-N910F using Tapatalk
darren.moss.355
Re: Mk4 epic fault codes
Postby DodgeRover » Thu Jul 13, 2017 8:15 pm
Minor Matt is the font of all knowledge on the EPIC system, not sure if the paper clip thing works on anything other than old vauxhalls though.
DodgeRover
Postby dumptruck » Thu Jul 13, 2017 9:48 pm
I did have a copy of epic fault codes somewhere but cant find it, but a quick search on google for ' lucas epic training manual ' turned up a copy for a LDV fitted with the same engine, last page lists fault codes. May be of some help.
http://www.ecovippari.com/uploads/6/4/6 ... manual.pdf
dumptruck
Postby Frag » Thu Jul 13, 2017 10:11 pm
Those are the STAR test codes for epic,
12 is standby code i.e. Start of readout ,
11 is end of readout.
Anything in between is fault codes,in pairs.
So 12,15,11 would be 15 (which relates to throttle pedal)
If you read codes as you have,then re-fit bridge wire for 10-12 seconds,after code 11,that should clear the codes.
Run it till fault occurs,then re check logged codes.
Frag
Ford Technician
Postby darren.moss.355 » Fri Jul 14, 2017 4:58 pm
OK thank you have just been out and cleared codes, ignition on n off re read codes none stored ran engine n re check ok drove round bloke for 5 min van started to kangaroo a few times but didn't cut out this time came back and now have code 55. Does any one no what this code is for please.
darren.moss.355
Postby Keef » Fri Jul 14, 2017 5:36 pm
Keef
Postby darren.moss.355 » Fri Jul 14, 2017 5:50 pm
Thank you keef that's very helpfull but it does list any 2 digit codes only 4. Are the 2 digits the last 2 in the 4 digits codes or something else
darren.moss.355
Postby Frag » Fri Jul 14, 2017 6:37 pm
I have a list of codes,
But 55 is not listed
51,53,54 are possible 'single' fault codes
I.e 12 53 11 (replace module)
You can have multiple codes,always in blocks of double digits.
Multiples can be in 'blocks' of 2 or 3 pairs of numbers.
So
11 16 22 24 12.
(Pump disconnected with ignition on)
Frag
Ford Technician
Postby MinorMatt » Fri Jul 14, 2017 9:56 pm
would it be possible to get a list of those codes please frag? I have sod all info on the mk4 system...
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby darren.moss.355 » Sat Jul 15, 2017 9:38 am
Me too please would be very helpful
darren.moss.355
Postby darren.moss.355 » Sat Jul 15, 2017 11:14 am
OK so been out and double checked I'm definitely getting 12. 55. 11. Also noted it didn't want to start but noticed when it didn't start the engine light wasn't lighting up with ING on turned on n off few times and it came on and started any ideas.
darren.moss.355
Postby DodgeRover » Sat Jul 15, 2017 10:29 pm
Bad ignition switch? I'm pretty sure you can buy the new switch part to go on your existing ignition switch
DodgeRover
Postby darren.moss.355 » Sat Jul 15, 2017 11:24 pm
Possibly but don't think so as don't think it would cause kangeroing and cuting out while driving intermittently
darren.moss.355
Postby darren.moss.355 » Wed Aug 09, 2017 7:05 pm
OK so update vans still playing up found out that when van doesn't start the eml isn't coming on and you drive it it keeps losing power and cutting out with the eml comin on n off just re checked the codes using the paper clip and now getting 55 and 35 dose anyone have any info on these please
darren.moss.355
Postby Frag » Wed Aug 09, 2017 10:25 pm
Seems you have a power supply issue,
Check battery condition,terminal tightness.
Power hold relay or high resistance in its contacts.
High resistance in power supply to module pin 32.
Check the battery earth that goes to panel at back of drivers headlamp.
Frag
Ford Technician
